CMV
A lot of threads here and the before/after pics of a light bar mounted on the ROPS looks like it makes a HUGE difference. I see lots of interesting pods, bars, etc on Amazon but wattage ratings anywhere from 18 to 500+.
So a couple of questions:
1. My factory headlights are 55/60 W. If I wanted to disconnect them and use their wiring to tap into, similar wattage light pods would be fine on that circuit and existing switch? The 55W is per light - not the pair correct?
2. Manual says hi/low beam. Maybe I'm an idiot, but headlights are either on or off. I haven't figured out any way to do high beams.
3. 300 watts 12VDC is 25 amps? What would be too much for my 50A alternator since it's also charging battery, running other lighting, running dash, fuel solenoid, and whatever else? I would assume asking it to deliver it's max whenever running extra lights wouldn't bee good for its long-term survival?
