XJ2025H Wheel spacers
   / XJ2025H Wheel spacers #1
tomplum
Elite Member
PNW
XJ2025H
I wanted to give the little LS a bit wider stance. I bought a set of 2" spacers from an EBay seller PE-Motorwerks for 100$. They fit great. I'll need to procure longer wheel hub bolts though as the spacer is slightly thicker than the wheel where the studs / bolts slip through. 2pc | 2 inch | Skid Steer Wheel Spacers - 6Lug Bobcat Case John Deere CAT Terex | eBay
The stance of the tractor looks better and seems better to me. No rear world tipping data to share. To do this I thought it best to install longer bolts (16x50mm?) from the rear of the hub and tapered nuts to fit the spacer. The auto parts store had like 3 wheel nuts so I looked on EBay and bought a set of Land Rover nuts for not a lot of money. Welcome to the forum!
   / XJ2025H Wheel spacers #4
Did you modify both the front and rear?
The rears only.
12ft. S/A Utility Trailer (A56859)
12ft. S/A Utility...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
2019 INTERNATIONAL RH613 (A58214)
2019 INTERNATIONAL...
(INOP) 2012 CATERPILLAR CT660S T/A DUMP TRUCK (A58375)
(INOP) 2012...
2019 C.GALLEGOS PNEUMATIC TRAILER (A58214)
2019 C.GALLEGOS...
Mini Excavator Bucket (A55272)
Mini Excavator...
