50 hr. Maint. - valves and head bolts
   / 50 hr. Maint. - valves and head bolts #1
LittleBlueTractor
Gold Member
Houston
LS S3010
My tractor developed a pretty loud tick starting about 6 months ago. One of the 50 hr. maint. check list items in the operator's manual for my S3010 reads: "Have dealer check valve clearance and torque head bolts". The service manual I bought describes the process in detail so I did it last week. (Yes, I know, no need to make fun of the fact that it took me 24 months to put 50 hours on it. ;)) I checked the gap on the valves before any adjustments and only the number 4 cylinder was right. The rest of the gaps were all too small. Happy to report that the tick went away after I adjusted the valves.
ANYWAY, I have seen a lot of you guys post about changing the fluids and fliters for the 50 hr. maint., but no one has mentioned the valves or head bolts. Is that NOT in your model's OM check list?
   / 50 hr. Maint. - valves and head bolts #2
No, nothing like that on our MF 1635 50 hour check list at all.
   / 50 hr. Maint. - valves and head bolts #3
600 hr valve & injector checks on by Boomer
   / 50 hr. Maint. - valves and head bolts #4
I don't recall anything in my manual (R3039) regarding valves and head bolts at the 50 hour service - of course I can't remember what I had for dinner last night either. You have peaked my curiosity so now I'll have to check the manual.
   / 50 hr. Maint. - valves and head bolts #5
Checked my manual and it does not mention valves or head bolts in the 50hr service.
   / 50 hr. Maint. - valves and head bolts #6
the kubota equipment i have state engine valve clearance adjust every 800hr.
   / 50 hr. Maint. - valves and head bolts #8
Always a good idea to check head bolt torque, and valve clearance at 50 hours. Always follow service manual when doing. May prevent future trouble , when out of warranty, down the road. Don't put all your trust in factory techs.
   / 50 hr. Maint. - valves and head bolts #10
NH TL80a - 900hrs. and the way it runs I think it needs it now at 600hrs.!!!! Anyone know the valve clearance specs for it????
Bob
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2022 CATERPILLAR 301.7CR EXCAVATOR (A51246)
2022 CATERPILLAR...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2013 Ford Explorer SUV (A51694)
2013 Ford Explorer...
CAT 336 D, Cab, Heat/Air Excavator (A52384)
CAT 336 D, Cab...
