Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Default 7010 with bush hog versus 1" pry bar
    A few days ago I wanted to check the bolts in my bush hog and had to use my 1" pry bar to turn the PTO shaft. Well I got the blade bolt tighened and decided to check the stump jumper so I wedged my pry bar in the yoke of the PTO shaft to keep from spinning while tightening.
    Well today I decided to do a little cutting and when I engaged the PTO it stalled the motor at idle so I increased throttle to 1500 and that when I saw pieces of the pry bar thrown about 15 feet to the side. It broke off a section about 10" long and bent the other piece into a shepherd hook.
    Yep, I forgot to remove the pry bar from the yoke when I finished. Lucky it didnt damage the bush hog other than the two support bars from the 3 ph to the rear (1" schedule 80 pipe) I jacked and come-a-longed them back straight. I guess Bush Hog builds some very strong universal joint yokes.
    I guess I need a checklist to remember to pick up and remove all my tools.
    I managed to cut off the bend and weld back the wedge end to make 2 foot long pry bar out of my 4 foot one.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  2. #2
    Gold Member rwork's Avatar
    Join Date
    Apr 2012
    Posts
    375
    Mississippi Gulf Coast
    Kubota B6100, LS R3039H
    Default
    Wow, that's scary! I've been guilty of leaving tools under the hood of the truck before. Good thing it didn't do much damage.
    Sent from my iPad using TractorByNet
    2012 LS R3039H, 6' Howse HD Box Blade, 4' Root Grapple, CID Stump Bucket
    1975 Kubota B6100, Craftsman Garden Tractor, eXMark Lazer Z mower.
  3. #3
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    Default Re: 7010 with bush hog versus 1" pry bar
    My fault for not removing the bar, but I blame it all on not having a way to feather in the PTO. That sudden slam in gear is rough on everything. I prefer the live PTO with 2 stage clutch rather than this electrically engaging buttons the tractors now have. If I had been feathering it in and the motor stalled, I would have looked for the cause but since it just slams in and I do it at idle I thought that was what killed the engine so I just increased the power a bit.
    My tractor runs 540 at about 1950 rpm but I found that it cuts well at 1500 rpm
  4. #4
    Platinum Member RDrancher's Avatar
    Join Date
    Aug 2011
    Posts
    969
    Sanger, Texas
    NH
    It should...Heck, it'll cut steel!
    Yesterday I hit ROCK BOTTOM.....Today I started to DIG..
    My Work & Stuff Photo Thread: http://www.tractorbynet.com/forums/p...to-thread.html
  5. #5
    Member
    Join Date
    Apr 2011
    Posts
    26
    ls 3010 TLB
    A pre trip inspection would work the best.
  6. #6
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    Yep, like a pre-flight of an airplane but who can remember to do that when I dont know where I am going and sometimes dont know why I went in the first place. Most of my tasks come about after doing a planned task and then thinking "why dont I do ???? while here.
    Any one else here ever walk into a room and say why did I come here and have to think for a moment and maybe not remember at all. Lots of times I will start working on one thing in my shop and end up doing 3 or 4 other tasks and maybe not finish my original work that day.
    Last week my BIL was gone all week to a funeral and I looked after his livestock and my chores. I stayed busy all day every day but could only recall a few of the things I did all week.
    Today we were originally out to trim some limbs. Ended up removing the blades from the lawnmower, straightening a rod and reinstalling it (which we found bent and loose while looking at the blades) then tried the pole saw and the chain was dull so went to town to get new mower blades and new chain for pole saw, had a flat tire on the way, so had to get it fixed, found out that somewhere in its life the truck had lost its jack handle and lug wrench so we couldnt get the spare down. Tire shop put two plugs in the large hole and no one had a 20" tire in stock in Arkadelphia, so hopefully it stays up till B-I-L can get someone in Hot Springs to get a new tire in stock Monday. Also has to go to Dodge dealer to order handle and lug wrench. Finally got around to trimming the limbs about 1PM and then while hauling off the limbs decided to build up a dam a little higher so some pools in the creek would hold a bit more water.
    Never did get those new lawn mower blades on. Finding those blades is another tale in itself. Stopped by Sears and they only had 2 of the 3 we needed and they wanted $27 each. Then we went to a small engine shop and of course they were closed at 12:15 on Saturday. Finally found them at Atwoods for $16 each so that saved a few bucks over Sears and having to order the other one.
    Just another typical day on the farm.
  7. #7
    Elite Member texasjohn's Avatar
    Join Date
    Oct 2005
    Posts
    4,736
    Central Texas, Jarrell
    Kubota 5030HSTC
    LOL...yep...I resemble your planned activities....I start out on one thing...and have to fix, move, repair, find, etc., a whole bunch of stuff ...it can be days before I finish that ONE THING
    Joy is having the tools you need and needing the tools you have!
    Kubota 5030 HSTC, BB, Danueser PHD, LA853 QA HD FEL w JD toothbar, 3pt chisel, 3 pt disk, 6' shredder, Kubota FEL hay spike, 3pt hay fork w carryall, Kubota RTV 1140
  8. #8
    Super Member
    Join Date
    Oct 2003
    Posts
    7,344
    Northeast, Ohio
    TC-40D SS New Holland
    The good news is that no one else was standing next to the PTO when you engaged it. Pry bars can be replaced, body parts can't. Have to admit that I made a more than a few mistakes that made me shake my head in disbelief too.
    Glad you're OK and there was no serious damage done.
  9. #9
    Platinum Member Sackett2's Avatar
    Join Date
    Feb 2008
    Posts
    705
    Eugene, Oregon
    Montana 4344HST
    Quote Originally Posted by Gary Fowler View Post
    guilty.. Mine was a crowbar; a cheap one. Bent it a bit and took out the shear-bolt. Lesson learned....
    Sackett aka "Steve"
    TSgt, USAF Ret. 1981-2001
    2008 Montana 4344HST
    4' Brush Hog; 6' rear blade; 6' box blade
    "Thanks for the tractor Rick"
    In memory of my brother
    Richard A. Hansen 1961-2008
    SSgt, USAF Ret. 1980-2000
  10. #10
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    Next time I will have to remember to put it behind the slip clutch rather than in front. A fellow cant remember everything at my age, heck even professionals forget to do something like put the dip stick back in after changing oil and really bad ones forget to put in the plug. We had a company truck engine burned up after oil change when the mechanic forgot to put the drain plug back in and all he did all day long was change oil, filter and air filter on our company fleet. Sometimes the mind just isnt where it should be.
Similar Threads
  1. Buying Advice 2002 BX 1800--bush hog 42" or 48"?
    By The Toolman in forum Kubota Buying/Pricing
    Last Post: 02-23-2012, 06:38 AM
  2. Rotary Cutter 60" or 72" Bush Hog for brush clearing with 40hp
    By IslandTractor in forum Attachments
    Last Post: 11-03-2011, 11:00 AM
  3. "New" 2 Yr. Old Bush Hog 295 Rotary Cutter
    By Mikey007 in forum Attachments
    Last Post: 07-28-2011, 08:52 AM
  4. "Pull" bush hog, or lift it when travelling?
    By beppington in forum Attachments
    Last Post: 10-13-2010, 06:46 AM
  5. Spud bar storage on FEL (Pry bar)
    By mars1952 in forum Customization
    Last Post: 03-23-2007, 03:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
