Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 46
  1. #11
    Bronze Member oldtoyboyd's Avatar
    Join Date
    Jun 2009
    Posts
    88
    Leesburg, MS
    LS R4047
    Default Re: $300 to load rear tires
    I paid 250 for rimguard for my R4047. 110 gallons
    LS R4047 Gear Shuttle Shift
    Fit Rite TnT
    Woods RD72 Heritage Finish Mower
    Woods BB72 Brush Hog
    NH 918H Flail
    United 672HD Box Blade
    United 600 20 x 20 Disc
    Homemade Quick Attach Trailer Mover/Lift Plate
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #12
    Elite Member Bob77064's Avatar
    Join Date
    Sep 2011
    Posts
    3,110
    KY @ TN line
    2011 LS R3039
    Quote Originally Posted by oldtoyboyd View Post
    That's a good deal for that.
  4. #13
    Super Member
    Join Date
    Apr 2000
    Posts
    5,608
    Cedartown, Ga and N. Ga mountains
    1998 Kubota B21, 2005 Kubota L39
    Bob it is not that hard to do it yourself. There have been many treads on the forum explaining the process. I do recommend environmentally friendly anti-freeze for the sake of any animals if you get a leak.
    MarkV
  5. #14
    Join Date
    Sep 2011
    Posts
    3,110
    KY @ TN line
    2011 LS R3039
    Quote Originally Posted by MarkV View Post
    MarkV
    Mark, I have thought about it and yes we do have animals.
  6. #15
    Join Date
    Apr 2011
    Posts
    597
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    Does anyone know the ratio for the antifreeze to water? This would be in Pa so it gets cold here.
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  7. #16
    Join Date
    Sep 2011
    Posts
    3,110
    KY @ TN line
    2011 LS R3039
    Quote Originally Posted by Guesseral View Post
    Use the same amount as you would in the cooling system.
  8. #17
    Join Date
    Apr 2011
    Posts
    597
    Erie Pa.
    Quote Originally Posted by Bob77064 View Post
    So 50/50.
    Montana R4944
  9. #18
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,741
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    50/50 mix would be good to -34F. Do you need that much protection. For tires a little slush doesnt hurt a thing in tires. I would think that a 30% antifreeze solution would be plenty for tires.
    You can look up the freezing point of different ratios on internet (lots of sites) and decide what you need to do. A device to fit on the garden hose to put in water is about $12 at NAPA maybe less at TSC.
    One TBN poster described the easiest way to get antifreeze in the the tires is to put tractor on jack, lower the jack to flatten the tire slightly then with the tire filling gadget on the tire and end of hose in antifreeze bottle, jack the tractor up and the fluid will be drawn into the tire by vacuum. Repeat as needed to get all the antifreeze into the tire. Have the valve stem at top dead center for all filling. When you stop getting air out and water comes out instead, the tire is full. You will have to stop filling with water and bleed the air a few times to avoid overpressuring the tire when filling. I filled my Yanmar tires when I got it several year ago in about 5 minutes per tire after getting the blocks in place for the jacks that it. Total time was about an hour for all of it including swapping the tires from each side to widen the stance prior to filling with ballast. I did have a helper on this as I didnt want the tires to get away and lining up the lug bolts was much easier with a helper.
    Check your pricing for the required amount of antifreeze and you can readily see how much your dealer is charging for labor. I wouldnt think more than 4 gallons per tire is required @ $10 or less per gallon.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  10. #19
    Join Date
    Apr 2011
    Posts
    597
    Erie Pa.
    Yea I have all of the stuff to load tires, done several with calcium but these are tubless tires so I want to go a different route. I will also be pricing the cost of the rimguard if it is within reason I'll get that instead. I just wasn't real sure on how much antifreeze I would need "yea I know I live in the cold I should know" 50/50 seemed a little strong to me and costly too it may have been less with rimguard at that mixture.
    Montana R4944
  11. #20
    Super Member
    Join Date
    Apr 2000
    Posts
    5,608
    I am sure Gary's method would work. I was a bit to lazy for that and bought a $10 little pump that is run by an electric drill. The rest of it was done with the bleeder valve that Gary mentioned. I'd price the cost of your anti-freeze of choice and see if $300 makes it worth while.
    MarkV
Similar Threads
  1. Ballast BX2360...load rear tires or wheel weights?
    By Mylesclark in forum Kubota Owning/Operating
    Last Post: 04-20-2009, 05:52 PM
  2. Tires Load rear tires?
    By dodge man in forum Kubota Owning/Operating
    Last Post: 04-18-2009, 08:31 PM
  3. Anyone Load rear tires of their L-39?
    By mike69440 in forum Kubota Owning/Operating
    Last Post: 12-14-2006, 09:19 AM
  4. 3015 tires--to load or not to load
    By pk1mk1 in forum Mahindra Owning/Operating
    Last Post: 07-28-2006, 12:26 PM
  5. Tires CK30 Load Rear Tires?
    By EldonC in forum Kioti Owning/Operating
    Last Post: 12-03-2005, 08:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
