Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
  1. #11
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,741
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Default Re: Hood latch
    Quote Originally Posted by kw22614 View Post
    Don't just leave it loosened, maybe put a washer under it to extend it to where you need it, then tighten it! IMO
    I didnt actually mean to leave it loose. Loosen the bolts and slide the latch down to adjust it and retighten. It has a slotted adjustment just like car hoods.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #12
    Silver Member Mike1369's Avatar
    Join Date
    Dec 2012
    Posts
    222
    Miami, Fl
    Baddest LS P7010C south of Palm Beach County
    Gary, thanks for clearing that up....lmao
  4. #13
    Gold Member kw22614's Avatar
    Join Date
    Dec 2012
    Posts
    264
    Manassas, VA
    Kubota BX1860
    I figured you knew Gary, I stated that for the benefit of the OP.
  5. #14
    Join Date
    Jun 2008
    Posts
    4,741
    Bismarck Arkansas
    Well, you are right, with some folks you do need to be specific and precise otherwise they get it all wrong.
    Like the blonde Jaguar owner who claimed her car wouldnt move at night. When questioned about proper operation of the transmission, she claimed that she knew how to drive and always used the right gear: she used D for day and N for night and it just wont work in N (ight) operation.
  6. #15
    Join Date
    Jun 2008
    Posts
    4,741
    Bismarck Arkansas
    Quote Originally Posted by Mike1369 View Post
    Did you get your hood adjusted so it stays closed now?
  7. #16
    Join Date
    Dec 2012
    Posts
    222
    Miami, Fl
    Default
    Won't be until Saturday... Real work gets in the way of fun work...lol
  8. #17
    Join Date
    Dec 2012
    Posts
    222
    Miami, Fl
    Default
    Ok went to farm today loosened the catch pin but when I tightened it back I got same results. Not sure what I'm doing wrong. May have to add washers.. :-(
    Locked down with ratchet strap... It ain't going anywhere now.
  9. #18
    Join Date
    Dec 2012
    Posts
    264
    Manassas, VA
    Kubota BX1860
    Click image for larger version.
    I'm sure if you'll get it
    Strap'll sure hold it till then.
  10. #19
    Join Date
    Jun 2008
    Posts
    4,741
    Bismarck Arkansas
    DO you have enough slots to adjust it. Mine had plenty of adjustment. Just loosen it up, slide it down as much as it will go and try that. You may have to slot it some more. If that don't work, get the dealer to work on it. Check the bottom latching mechanism. It may be loose or mal-adjusted also. It has to be just an adjustment issue
  11. #20
    Join Date
    Dec 2012
    Posts
    222
    Miami, Fl
    Default
    You know if it was a broken bone or torn ligaments I wouldn't be so hesitant to work on her... Need to change mentalities once I hit the farm. Will sneak over during the week to give it another shot.
Similar Threads
  1. BX Hood Latch Surprise
    By CHDinCT in forum Kubota Owning/Operating
    Last Post: 04-28-2012, 10:53 PM
  2. BX 22 Hood latch
    By Tdog in forum Kubota Owning/Operating
    Last Post: 10-03-2007, 10:16 PM
  3. Opening Hood with a Broken Hood Latch?
    By Nicole in TX in forum Kubota Owning/Operating
    Last Post: 04-18-2007, 08:55 PM
  4. TU155FD HOOD LATCH
    By RJB in forum Iseki
    Last Post: 03-30-2004, 03:41 PM
  5. TC45 Hood Latch
    By Fullthrottle in forum New Holland Owning/Operating
    Last Post: 07-22-2002, 11:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
