Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. #21
    Silver Member Mike1369's Avatar
    Join Date
    Dec 2012
    Posts
    222
    Miami, Fl
    Baddest LS P7010C south of Palm Beach County
    Default
    Ok worked on hood latch for like 30 min, tried everything with no avail. We try Steve on Monday.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,741
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Default Re: Hood latch
    You must have a defective latch then. Will dealer come out an install or just give you the new latch OR will you have to haul it to his shop?
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  4. #23
    Join Date
    Dec 2012
    Posts
    222
    Miami, Fl
    I hope I don't have to take it to the dealer... He's 600 miles away...lol
    I will call Steve to see my options... Latch is only 4 screws.. I can do that easily.
  5. #24
    Join Date
    Jun 2008
    Posts
    4,741
    Bismarck Arkansas
    Is there any linkage adjustment on the hood release cable. I didn't have any issues other than adjustment of the U hook but perhaps that is what is happening. The cable might be to short and actually pulling the release.
  6. #25
    Join Date
    Dec 2012
    Posts
    222
    Miami, Fl
    Nope, cable is fine.
    Really not 100% sure what's going on.
    Will keep everyone posted
  7. #26
    Gold Member kw22614's Avatar
    Join Date
    Dec 2012
    Posts
    264
    Manassas, VA
    Kubota BX1860
    Post some pics if you can of the hook and attachment on the bottom of the hood, the latch and attachment inside the motor compartment, and where the 2 meet - if you can get the camera in there close enough. Make sure the entire motor surround is all the way seated - down and back, if removable, as if it's mounted to high or forward the hood will never line up.
  8. #27
    Join Date
    Dec 2012
    Posts
    222
    Miami, Fl
    Default
    Took some pictures today. I think the pin is set way to back and is only catching the front of the pin on latch. Going to buy some washers to move forward.
  9. #28
    Join Date
    Jun 2008
    Posts
    4,741
    Bismarck Arkansas
    It has been over 2 years since I had to adjust mine and cant really remember what I did other than I remember it wasn't engaging far enough. IT would hold till I put pressure on the FEL and then it would pop open. I haven't really paid a lot of attention since then
  10. #29
    Join Date
    Dec 2012
    Posts
    264
    Manassas, VA
    Kubota BX1860
    By the grease mark on the pin it almost looks like you may need to remove one washer to push it more forward to catch more pin in the latch. Try to keep the lock washer and lose the bigger fender washer if there's enough shoulder on the pin to hold it in the mount. Can you maybe take another pic of the pin down close to the latch, ie the hood almost closed to show how the two should mate (just enough room to fit your camera)?
  11. #30
    Join Date
    Dec 2012
    Posts
    264
    Manassas, VA
    Kubota BX1860
    Another thing you might try is the latch. It may be stuck in the closed position so it will never close around the pin.
    By your picture try to push the 2 ears(above the bracket) opposite of eachother until they click and stay - this may take a little force.
    There's only a few things it could be, I'm sure almost anyone, mechanicallly inclined, you know may be able to easily fix it for you.
    Hate the idea of 600mi trip back to dealer. Very minor prob though, could be much worse. Good luck and let us know the outcome. KW
Similar Threads
  1. BX Hood Latch Surprise
    By CHDinCT in forum Kubota Owning/Operating
    Last Post: 04-28-2012, 10:53 PM
  2. BX 22 Hood latch
    By Tdog in forum Kubota Owning/Operating
    Last Post: 10-03-2007, 10:16 PM
  3. Opening Hood with a Broken Hood Latch?
    By Nicole in TX in forum Kubota Owning/Operating
    Last Post: 04-18-2007, 08:55 PM
  4. TU155FD HOOD LATCH
    By RJB in forum Iseki
    Last Post: 03-30-2004, 03:41 PM
  5. TC45 Hood Latch
    By Fullthrottle in forum New Holland Owning/Operating
    Last Post: 07-22-2002, 11:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
