Results 1 to 10 of 15
01-28-2013, 03:39 PM #1Gold Member
- Join Date
- Apr 2012
- Posts
- 381
- Location
- Mississippi Gulf Coast
- Tractor
- Kubota B6100, LS R3039H
Up To My Neck In Stumps!!
Just about the time I think I've got all my stumps dug up, I stumble on another one! I found this one underneath my burn pile. Turns out this might be a challenge. It's an old stump, no sap left, all fat wood. I hitched up my trusty stump bucket, and proceeded to dig....and dig. Got down to about five foot, as thats as deep as I can dig down with the stump bucket, without falling in the hole!
Still can't get this thing to budge. It looks like this one is going to have a six to eight foot tap root! It's over three foot across, and I think I'm going to have to dig a ramp down into the hole, so that I can get the tractor down to dig a little deeper!
01-28-2013 03:39 PM # ADS
01-28-2013, 03:43 PM #2Gold Member
- Join Date
- Apr 2012
- Posts
- 381
- Location
- Tractor
Re: Up To My Neck In Stumps!!
Here's some little ( 5 footers ) that I've already dug with the stump bucket.
01-28-2013, 03:47 PM #3Elite Member
- Join Date
- Jun 2008
- Posts
- 4,741
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
If you dig out on all sides like you have done there and still cant get it out, then just pile the brush pile back on top and set it on fire. IT should burn to ground level. Then just backfill it.
However from my experience in digging out stumps with the backhoe, it looks like you are almost there. Those stabilizing roots the run to the four corners are likely what is holding you. Try to cut thru those with your stump bucket or saw and the tap root should just lift right out. You may have to dig the other side out also to expose the roots from that side but it may come loose when you get the ones expose now cut thru. Don't worry about the tap root, it is tapered and should just lift right out when you get the others cut.2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
01-28-2013, 03:56 PM #4Gold Member
- Join Date
- Apr 2012
- Posts
- 381
- Location
- Tractor
Gary, I did manage to break through those other roots, but she's still held tight. I'm down to that good ole sticky yellow clay.
Got a nice stick of dynamite laying around!?!
01-28-2013, 04:07 PM #5Platinum Member
- Join Date
- Apr 2011
- Posts
- 599
- Location
- Erie Pa.
- Tractor
- Montana R4944, Ford Jubilee, Ford 621, Ford 841
Oh just pile it up with other wood get some beer and invite your friends over for a bond fire she'll burn right down into the earth. Of course you should level it out around there if there is beer involved!
Montana R4944
Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
01-28-2013, 04:35 PM #6
01-28-2013, 07:43 PM #7Veteran Member
- Join Date
- Jun 2006
- Posts
- 1,290
- Location
- West Cascades Washington State
- Tractor
- PT 422
01-28-2013, 07:54 PM #8Gold Member
- Join Date
- Feb 2001
- Posts
- 380
- Location
- Franklin, Maine
- Tractor
- Kubota M59 ,JD 4700 MFWD
pressure wash them and have them saw-milled. Expensive, but nice looking boards.
David
01-29-2013, 12:14 AM #9Gold Member
- Join Date
- Apr 2012
- Posts
- 381
- Location
- Tractor
In case you didn't notice, I'm standing in the hole, and that's the stump my arm is resting on. I'm guess there's another three foot still underground!
2012 LS R3039H, 6' Howse HD Box Blade, 4' Root Grapple, CID Stump Bucket
1975 Kubota B6100, Craftsman Garden Tractor, eXMark Lazer Z mower.
01-29-2013, 07:34 AM #10Platinum Member
- Join Date
- Apr 2011
- Posts
- 599
- Location
- Erie Pa.
- Tractor
Had a bond fire over a stump last summer, it was at lease 3 1/2 feet accross it was still burning 4 days later down under the ground. Burried the 2 1/2 foot deep hole after 5 days figured that was far enough down. No that was a pretty dead tree so it burnt very well.
Montana R4944
Similar Threads
neck pain
By sherpa in forum Rural LivingReplies: 10Last Post: 03-15-2012, 12:17 AM -
Neck injuries
By DCS in forum Owning/OperatingReplies: 41Last Post: 11-01-2006, 08:21 PM -
Another you might be a red neck if...
By cchoate in forum Rural LivingReplies: 5Last Post: 07-02-2005, 10:35 AM -
Help with Neck
By Yanmar_1700 in forum YanmarReplies: 3Last Post: 10-01-2004, 10:39 AM -
Pain in the Neck
By Tdog in forum Owning/OperatingReplies: 7Last Post: 03-23-2004, 08:14 PM
