Page 6 of 7 FirstFirst ... 34567 LastLast
Results 51 to 60 of 68
  1. #51
    TSO
    TSO is offline
    Veteran Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    1,536
    SouthEast Michigan
    Massey 1648 HST Cab
    Default
    Quote Originally Posted by Short Game View Post
    Correct. It wasn't an LS. It was a CubCadet that Mitsubishi made for them. The previous owner had broken the ring and pinion too. He did it by driving into a canyon with backing back up the hill the only escape (which failed). He did his reverse wheelie that way. I did mine more like your picture, and breaking way more parts.
    Well, my LS brochure says it has a heavy duty front axle, so it can't possibly break!
    JK, I'll keep your experience in mind.
    Massey 1648 HST Cab
    Previous: LS R4041/4047 & Kioti CK20S
    QA 72'' bucket * 60" Custom Grapple Bucket * QA Forks * 8' HD Back Blade * 84" HD Box Blade
    72'' Rake * WorkSaver SG-26 Stump Grinder * Middle buster plow * Wallenstein BX42s PTO Chipper
    Hustler Z Diesel 66" ZTR mower (25 hp Shibaura diesel)
    20' PJ Equipment Hauler/Trailer
    2008 F250 Crew V10 4x4
  2. #52
    Platinum Member deezler's Avatar
    Join Date
    Jan 2012
    Posts
    554
    Southeast MI
    Cub Cadet 7305
    Default Re: My biggest stump
    Well, if my post saves anyone from doing what I did, it was worth the time to read it. I tried to lift a log that had silted in branches under it. The instant the rear wheels lost traction, the front drive failed catastrophically. Both half shafts bent, but I was able to straighten them. I broke two small pinions, both the ring and pinion, one sun gear, and two bearings. It was only twelve pounds of parts, but they cost $2000 from Mitsubishi to replace them with me doing all the labor.
    Ruh roh. I guess I need to learn to never do this with my 7305 then, huh? So you were backing up and lifting, when the rear wheels lost traction, putting all the strain on your front drive? I wonder if your failure was at all related to the previous owner already failing these parts ?
  3. #53
    Join Date
    Jan 2012
    Posts
    554
    Southeast MI
    Cub Cadet 7305
    Oh and since this is a stump thread, I've been building this pile over the last few weeks. I feel bad for my tractor, she's been working pretty hard.
  4. #54
    Elite Member
    Join Date
    Jun 2011
    Posts
    2,985
    Sunny SW Washington
    LS R4010 & Cub Cadet 7300
    Quote Originally Posted by deezler View Post
    Henh, I recognized your Cub from the loader joystick, Deez.
    Yes, yes, and no.
    When the previous owner broke it, he took it back to the his dealer, Fly-By-Night Tractor Sales (no longer in business). Their non-mechanic got the wrong ring gear (an earlier iteration, probably for the 1991 Case IH 1140 -- same basic tractor) with 8mm ring gear bolts. They installed it with 8mm bolts through the differential case's 10mm bolt holes. Of course, they all sheared off just after I got the tractor (at the bottom of a steep four-wheel-drive hill). So, I did my first rebuild of the front drive at that time. Then later, when I killed it, and I did it in style. That catastrophe was all of my own doing.
    But right here, I will tell you about another weakness in that Cub's front drive. It is in the ball bearing outer front wheel bearings. So, I have had to replace that bearing more than once as well. If you put too much front end weight on one of the front wheels, the downward force on the bearing can blow the rivets out of the ball cage. The torn up ball cage then finds its way around to the seals and the gear oil hemorrhage will let you know something is amiss. By that time, the inner bearing will be getting some out-of-round balls and need replacing too.
    Who would have known I would wind up an expert on this front drive?
    I love the fuel economy of that K3M engine, enough to buy my 7300 (plus with my dead 7274, I have a quarter million dollars in spare parts!). If you want a dead CubCadet too, then never check or tighten the engine to frame bolts (don't miss the four on the front of the engine -- two studs and two bolts -- they are hard to access, but they are there). I learned a lot with my first tractor. For one thing, I am tractor addicted. I can't go back, take the cure. Lord have mercy, I now have two tractors.
    The Corporate Empire is NOT a Constitutional Republic...
    ...but it plays one on TV.
  5. #55
    Member
    Join Date
    Aug 2009
    Posts
    40
    Here are a few shots of my stump removal over the years..
  6. #56
    Member
    Join Date
    Aug 2009
    Posts
    40
  7. #57
    New Member
    Join Date
    May 2013
    Posts
    1
    Wilton Ca
    1977 Bolens G14
    Luck to have a big tractor.I have a Bolens and is no use pulling stumps.I use a shovel,Ax and my pickup. Glad I only have three
  8. #58
    New Member
    Join Date
    Apr 2013
    Posts
    2
    Huntsville, Alaama
    Kubota Bx 25
    Well;
    This girl got her very own tractor in May, and took out her first stump. I bought a kubota BX 25D 4WD, Loader, Backhoe, Scraper, and mid Mower setup. My first stump took me a while, with a 25hp but for a home with 2.5 acres, it was just the right size. Did I mention I had to put weight in the loader to keep the front wheels on the ground to move it to the burn pile"
    Attached Thumbnails Attached Thumbnails My biggest stump-2013-new-tractor.jpg
  9. #59
    Member
    Join Date
    Aug 2009
    Posts
    40
    Quote Originally Posted by tamara14 View Post
    Well;
    Click image for larger version.
    I pretty much pushed and rolled mine away... even with the full size machine.
  10. #60
    New Member
    Join Date
    Sep 2009
    Posts
    18
    Kubota M6040
    Just a thought - I have found that big stumps are most easily removed while still attached to the big, heavy tree..... method:
    1) Attach a wire rope as high up the trunk as possible.
    2) Dig round the stump
    3) Use a winch on the wire rope to pull the tree over, the trunk acts as a huge lever arm.
    4) Cut the stump away.
    One I did earlier:
    Cheers,
    Duncan
Similar Threads
  1. Biggest trailer I've ever seen!
    By Mace Canute in forum Trailers & Transportation
    Last Post: 02-10-2012, 07:45 PM
  2. Biggest one I'VE done
    By KPark in forum Projects
    Last Post: 08-02-2009, 09:56 PM
  3. Biggest forks ever
    By AKwelder in forum Build-It Yourself
    Last Post: 11-25-2008, 03:44 PM
  4. Stump Removal vs Stump Grinding
    By BoneheadNW in forum Owning/Operating
    Last Post: 06-22-2005, 02:16 PM
  5. Taking out a stump, a BIG stump
    By karmakanic in forum Projects
    Last Post: 06-29-2003, 04:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
