Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
  1. #11
    Super Star Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    17,156
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: Picked up a new toy for the 4041.... not sure if I'm gonna keep it tho
    From what I have seen of grinding videos, on little stumps like you have mentioned, about 5 minutes to get set up and finish grinding them down. Of course grinders are not cheap, and the teeth do wear out. Your stump bucket looked like it worked, just not all that quick.
    James K0UA
    James KUA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner How to add a link to a post . Best way to search TBN
  2. #12
    Platinum Member KYDan's Avatar
    Join Date
    Sep 2011
    Posts
    753
    Frankfort, KY
    Kubota MX5100 HST 4WD
    It sure looked messy though. From what I have seen of stump grinders they do not mess up the ground nearly that much. Even if they take longer by the time you wait for the ground to dry out and then smooth it out I would think the total chore time would somewhat equal out.
  3. #13
    Elite Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    2,616
    SouthEast Michigan
    Massey 1648 HST Cab
    Default
    I hear what you guys are saying about the time issue, but using this thing on the 4041 really seems to work it hard, and I have a feeling that I'll hurt my loader if I keep trying. Not to mention that I'm only starting out with the small stumps, most of mine are much bigger than the few that I tried so far .
    Of course the grinder works the PTO, but I think I've watched every video on youtube relating to it, it looks like it doesn't work the tractor nearly as much as the bucket.
    I agree that the stump bucket could come in handy for other things too, especially trenching and digging out rocks, so if I can afford to keep it and get a stump grinder, then that's what I'll do.
    On a positive note it was able to pop out saplings and other small trees with little effort... It might be handy for transplanting small trees
    Massey 1648 HST Cab - Hustler Z Diesel 66" mower
    John Deere Gator 620i - 2007 F450 Crew
    6ft bucket * 5ft Tooth/Tine Bucket * QA Forks * 8ft Rhino BackBlade
    7ft Rhino BoxBlade * 7ft LandPride Rake * 6.5ft KK HD Box Disc * Middle buster plow
    WorkSaver SG-26 StumpGrinder * Wallenstein BX42s Chipper * 8ft Ford Brush-Mower
    7.5ft QA snow plow
    Massey = 450 hrs @ 4/23/15
  4. #14
    Join Date
    Sep 2011
    Posts
    753
    Frankfort, KY
    Actually a rock/debris bucket is far superior for rocks than the stump bucket and you won't displace so much dirt and it doesn't work the hydraulics nearly as much. So many toys, so little money.
    -img_6118-1-jpg
  5. #15
    Join Date
    Jun 2009
    Posts
    17,156
    Branson, Mo.
    If you got it "right" I would keep it and still get the grinder as money allows. I used my homemade "shovel" attachment over the weekend to transplant a bunch of Jonquils for the wife.. Saved a lot of hand digging. I think the stump bucket would still be good for smaller things, and I would like to have it.
    James K0UA
    James KUA
  6. #16
    Join Date
    Apr 2012
    Posts
    2,616
    SouthEast Michigan
    Massey 1648 HST Cab
    Quote Originally Posted by KYDan View Post
    -img_6118-1-jpg
    I would agree about debris and smaller rocks, but for bigger rocks, I'm thinking the narrow tip on the stump-bucket (about 12") and the teeth... would help remove them more than a full width bucket, especially for how much ground you end up disturbing.
    K0ua, I agree... only so much "toy-money" to go around, sometimes I have to recycle one to get another. We'll see... I may start shopping around again, but I still need to get a grapple first as I have more immediate uses for that over a grinder.
    7.5ft QA snow plow
  7. #17
    Platinum Member the old grind's Avatar
    Join Date
    Jul 2012
    Posts
    727
    Mid-Michigan
    NH T-1520 HST, JD 5210 2WD, Terramite T5C
    Neighbor, I'd advise keeping the tree bucket. Even with a BH sometimes you have to loosen things up around a stump before all the roots will break loose, and your technique will improve with time. A friend's 70hp JD BH doesn't snatch 'em out in just one or two dips of the stinger bucket, and I mean medium sized ones like you're digging. IMO you do have enough tractor for such tasks. btw: 'Rip-out power' is rated at the bucket's pivot, and you lose quite a bit to leverage with the long point.
    Years ago I had apple stumps ground out. Chip litter in the back-fill didn't help to get grass growing over the spots. Gradual decay of the roots caused mini sinkholes and I was leveling them up for years afterward, not something I'd want to drive more that a mower over for quite a while.
    TSO, PM coming your way if you're not sure you have the right tool for the task. I'd love to have something like yours to shuttle white pines around my dunes.
  8. #18
    Elite Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    3,994
    Meridian, OK
    Bobcat V417 Toolcat 5610 F TORO+Loader
    TSO,do you think this narrower shape would work any better on your tractor?
    -s-b-jpg -s-b-1-jpg
  9. #19
    Platinum Member rwork's Avatar
    Join Date
    Apr 2012
    Posts
    591
    Mississippi Gulf Coast
    Kubota B6100 LS R3039H
    TSO, I've had good sucess with my stump bucket on my R3039H. Mine is a bit different design, though. It has a more narrow taper to the back of the bucket, and has the ripper teeth on the bucket edges. I can easily push my bucket into the ground, lift as I back up, and tear through the roots. I've dug out some really deep pine tree stumps with mine. I can actually dig down 5 1/2' with mine. Of course, I had to pay quite a bit more for mine.
    Attached Thumbnails Attached Thumbnails -kgrhqv-hkfblyzpf5mbqydi06j3-60_3-jpg   -2013-03-17-10-59-a   -2013-03-17-10-53-a
    2012 LS R3039H, 6' Howse HD Box Blade, 4' Root Grapple, CID Stump Bucket
    1975 Kubota B6100, Craftsman Garden Tractor, eXMark Lazer Z mower.
  10. #20
    Join Date
    Apr 2012
    Posts
    2,616
    SouthEast Michigan
    Massey 1648 HST Cab
    Quote Originally Posted by rwork View Post
    Quote Originally Posted by Xfaxman View Post
    -s-b-jpg -s-b-1-jpg
    To be honest... Pine stumps are the least of my worries and aren't in the same class as what I'm digging out, which is mainly oak & maple. I originally looked at the narrower ones, and that's what I was going to order (had I not found this one at auction) based on the same thought-principle that you mention.
    However, after using this one (up to about 10 stumps now) I don't think that the narrower version would make much difference, if any, on OUR SIZE tractors. The limiting factor is still the loader strength & dynamics. The actual part of the bucket that is in the ground digging is the narrow tip anyhow, so the ones pictured would have about the same functionality. With that said, I am definitely getting better with it, and learning how to use it better. BUT ... I've been sticking with the smaller stumps.
    I just got done removing another 4 stumps, which only took me about 30 mins combined. These were all pretty close together, so ripping through roots of 1 probably also ripped through some of the other roots too. These stumps were ranging from 5-8" I would say. I think that this implement really shines with the smaller stumps like this. I just don't know if I would have the patience or the time (probably take several hours) to dig out one of my bigger stumps, which range from 12"-32", and I have plenty of those still.
    -5-2-13-011-jpg
    -5-2-13-013-jpg
    -5-2-13-014-jpg
    -5-2-13-015-jpg
    -5-2-13-019-jpg
    -5-2-13-020-jpg
    -5-2-13-021-jpg
    7.5ft QA snow plow
Similar Threads
  1. Winches New toy for tractor
    By landedakioti in forum Kioti Owning/Operating
    Last Post: 05-11-2013, 06:52 PM
  2. New sample toy for the front of tractor
    By landedakioti in forum Kioti Buying/Pricing
    Last Post: 05-11-2013, 12:22 PM
  3. Vermont Ls 4041 with backhoe
    By Sharpservices in forum Private Party Ads
    Last Post: 01-28-2013, 10:59 PM
  4. New 4041 with a digger
    By Sharpservices in forum LS Tractors
    Last Post: 11-28-2012, 07:20 PM
  5. Buying Advice LS 4041 or 4047
    By Reeltruth in forum Buying/Pricing/Comparisons
    Last Post: 08-20-2012, 11:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
