"Cab" project for my R4047
   / "Cab" project for my R4047 #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
DISCLAIMER: This is a work in progress !!! I'm a beginner welder (getting better and better as I go) so if you're a pro and see something that isn't perfect, take it easy on me.
Anyhow, I've been wanting to build something to cover a few different things for me. First off, I've been wanting a canopy. 2nd, I've been wanting a 4-post frame for my ROPS so I can add said canopy, more lighting (front & rear), and a few extra storage areas. I'm also planning on building a hood-protector that will integrate into the (to be built) front grill guard, and will protect the hood from debris. The front posts will also help protect me from branches & limbs that like to whip back on me when in the woods and moving brush. Finally, I've been wanting the ability to bolt something on for the winter to give me some wind protection. I like an open station much better than a cab (although they are nice if they fit your function) but I wanted something convertible that I can slap on a windshield and sides to keep the wind off me in the winter. I'm most likely not going to add any type of heater, this would again just be a wind shelter.
Oh... and don't mind the messy barn. I have no fewer than a zillion projects going on at any time, and especially one like this tends to get cluttered with all the tools used.
So to the build:
First off, I needed a new "upper ROPS" for the back that I could attach the frame work to. I decided to shorten it a bit so that it could fit under my short barn garage door, and my actual garage doors... if needed. So, here you can see that I removed the upper ROPS portion.
And here you can see the new upper ROPS that I built to replace the factory one. I also included a tab on the back to mount exterior lights (don't think I got a picture of that tho...). The vertical bars are 2x2x1/4" tubing, and the angle iron is 2x2x1/4" as well. I made plates to match the factory mounting points to the lower ROPS portion and used the factory bolts/pins.
To tie the front portion to the tractor, I used 1x1x1/8" tubing and tied into the lower "mud-shield" framing. The tubing (and mounting points) are strong enough to support the frame & such... but would most likely be destroyed by a roll-over. Luckily I don't plan on doing that, and the upper ROPS that I built should be as strong as the factory one, albeit a bit shorter. The horizontal "roof" pieces are angle iron, with the 1x1 tubing for cross bracing. Regardless, I should still be safe in the event of a tumble.
So, here it is all together and bolted up. I still have to add a few more brackets for some storage & lighting, but otherwise, it's complete & functional. I also still need to paint it and add the roof. I'm still not 100% sure on how I'm going to finish off the roof, but I'll most likely use Plexi-glass so I can still see out of the top. I don't know if they make it tinted or not, but if so, that'll be my choice. Otherwise, I'll spray it with some tail-light tint spray.
Eventually, I'll build a quick-attach front windshield panel, as well as some side & rear panels for the winter. No hurry though now, this build only took me 2 days (much faster than I thought) so I'm ahead of schedule on it! More to come when I have new pics, paint, etc.
   / "Cab" project for my R4047 #2
Might be a little late for a suggestion on the windshield, but check out 'golf cart' windshields. they are designed to snap onto a 1" square tube....
Also, I am fond of a version of 'sign' board, that is basically plastic sheet laminated with aluminum on each side. Its reasonably strong, and very light. I used it on the roof of my golf cart. I have pics someplace, I will try to find them later for you.
Good suggestion on the golf cart windshield. I think I'm gonna stick with something transparent for the roof, sometimes I need that view when under trees & such
   / "Cab" project for my R4047 #4
If you want clear for the roof, I would go thick.... otherwise it may give you a false sense of security ;-)
Also, if you cant get it tinted, just apply car window tint, to the bottom side
Yeah, like I said this is built more for shelter, storage, lighting, etc... Than frame strength. It'll withstand the errant tree branch and such, but I'm not expecting it to protect me from meteors.
1/4" plexi, along with the cross supports that are on the roof frame, should be more than sufficient
   / "Cab" project for my R4047 #6
I was just thinking of that 'false' sense of security a roof may provide towards falling branches and such. Your framework will handle a good blow, but I am not sure about 1/4" plexiglass. Hard to say really... just my thought on it!
No prob Mangus, any comments/concerns/insights are welcomed... it's an evolving project. I drove it around a bit today to get a feel for it, gonna have to find a way to dampen the vibrations because the engine vibration and ground-bumps really resonate through the frame.
Here's a couple "outside" pics today.
   / "Cab" project for my R4047 #8
Wow...this is ambitious! Get it all sorted out, and don't take any shortcuts....then you can make me one after you have it all perfected :D
:D LOL... this is what happens when you have just the right amount of scrap metal sitting around, too much time on your hands at night when the wife & kids are asleep.... and just the right amount of alcohol to keep the creative juices flowing, but not too much to get ya hurt .
:dance1: :tractor:
   / "Cab" project for my R4047 #10
Do you always drive around with your brush guard down? My loader doesnt clear mine!! so I cant ;-)
golf cart electric (A55787)
golf cart electric...
White Metal Roof Panels (A55758)
White Metal Roof...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
14ft x 20ft Single Garage All Metal Building (New/Unused) (A59225)
14ft x 20ft Single...
