Thinking about getting a grapple. Any reason not to use my up-to-now unused rear remotes?
Hose and fittings from NAPA and some way to run the lines down the loader?
I've got a spare 8' snowplow blade that I want to hook up also, so need hydro out the end for 2 things.
Never used those rear remotes, so want to make sure they will work the way I want them. They are two-way, spring loaded back to neutral. I want to go grab something with maybe a lot of pressure or a little by using that remote lever in one direction; when it springs back to neutral, will the pressure stay on the grapple until I push the lever the other way?
