I have 300 + ac with 160 of that in pasture that gets brush hogged once a year in those years I don't
cut hay.
I also have a 1/4 mi entry road that washes out regularly and has to be maintained with a dozer, box scraper and 10' land leveler.
I also have a LOT of downed trees from recent storms that have to be
cut up/moved and burned.
I have several acres of fields that have grown up in red cedar, wild plum and sassafras that have to be cleared.
I am also building a 2400ft airstrip that is 80% done.
I also have two building pads to make prior to erecting two small pole barns.
I also have a 5500 sq ft shop building with 70 oak pallets that need to be moved/loaded/unloaded using a bucket with pallet forks.
I also have a small pond to rebuild and seal.
I also have several miles of old barb wire fences to remove.
I also have a set of gate posts to replace.
and on and on...
Be aware I presently have a 2WD White 105, an old 120hp
4WD Case 1200 and an 8N. The Case is only used with a 5 yd pull behind earth mover.
What those can't do... I have a Allis Chalmers HD6G High Lift Track Loader to fill in.
The Mahindra will serve as my general purpose tractor and fill a long empty hole between the 8N and and White 105.
I'm 61, retired and have been doing this for awhile.
Kerry
