Page 12 of 40 FirstFirst ... 2910111213141522 ... LastLast
Results 111 to 120 of 398
  1. #111
    Super Member
    Join Date
    Feb 2006
    Posts
    6,763
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Default Re: kobota bx25 vs mahindra max 25
    Quote Originally Posted by rockshaft View Post
    I think the bucket on the 1-series looks too big- but better too big than too small!
    What kind of quick attach does the Max bucket have?
    Quote Originally Posted by lwalsh View Post
    None, pin on.
    Poor.
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, Hesston Haybine, JD Rake
    Bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  2. #112
    Gold Member kootch88's Avatar
    Join Date
    Feb 2012
    Posts
    477
    Gray, Me
    2012 Mahindra Max 22, JD Stx38, JD Stx46
    Quote Originally Posted by LD1 View Post
    None of us would be having these arguments at all if the MAX website compairs to similar machines...IE 20 series and B-series. But they are intentionally trying to mis-lead customers. And make them think that this is the mahindra equivellent to the 10 and BX, but it most certainly is not.
    No mission and nothing against the MAX. I am quite sure it is a great tractor. The issue is the way they are marketing/comparing it. Mahindra acts like they came up with something totally new here Building a B or 20-sized machine and "calling" it a SCUT and comparing it to MUCH smaller tractors. Kinda puts a bad taste in peoples mouths that know he truth.
    Seems like the only folks with the bad taste are Kubota owners. Some of us just got into a tractor and if they were like me, they looked at just about every tractor in the sub/cut category out there. Kubota makes a great tractor, so does Deere, so does Kioti and IH etc. Enjoy your tractor and try and get over the bad taste, it seems it has wrecked a lot of lives somehow.
  3. #113
    Join Date
    Feb 2012
    Posts
    477
    Gray, Me
    Quote Originally Posted by SPYDERLK View Post
    Poor.
    I just removed the loader on my tractor for the first time. I did it with my wife at the controls, which slowed things down, and I am slow too being in a wheelchair, but it took all of 5 minutes to complete the task. Are other tractors quicker? Mine is a Max 22.
  4. #114
    Veteran Member magicheater's Avatar
    Join Date
    Jul 2009
    Posts
    1,665
    central Wisconsin
    Kubota B7800
    Quote Originally Posted by kootch88 View Post
    I believe he was referring to the "Bucket" Q/A, not the "loader" Q/A
    Working to increase the scope of the small tractor experience, one quick attach at a time.
  5. #115
    Gold Member rockshaft's Avatar
    Join Date
    Feb 2012
    Posts
    258
    Sterling, AK
    1026R
    I hadn't had a good look at the loader bucket connection on the Max series. I wasn't sure if there was some type of quick attach there. It's a big plus for me if I can swap out a bucket for forks in a timely manner.
    Max has lower horsepower loss between engine and PTO- they use this fact in their marketing. I wonder how they accomplished this? Seems like it would come at some cost? Why is their HST engineering superior to other brands in this regard?
  6. #116
    Join Date
    Jul 2009
    Posts
    1,665
    central Wisconsin
    Kubota B7800
    Quote Originally Posted by magicheater View Post
    Correct on the non rigid hydraulic lines. On the Max25 the bucket brackets do not have a bushing on one side. Just my observations because I look at this interface all the time.
    Here is a pic from my research mission. The brackets are 3/16" material vs. the standard 1/4". By no means am I condemning the Max series, only pointing out differences I have noted and feel compelled to add to this debate. There are no bucket stops either. The machine does have a rather wide stance and a roomy operator platform.
    Attached Thumbnails Attached Thumbnails kobota bx25 vs mahindra max 25-dscf1220.jpg
  7. #117
    Join Date
    Feb 2012
    Posts
    258
    Sterling, AK
    1026R
    Any zerks on those pins?
  8. #118
    Veteran Member AchingBack's Avatar
    Join Date
    Jun 2005
    Posts
    1,593
    Southern Oregon
    Mahindra 2615HST
    Of course there are. Have you seen loader bucket pins without them?
    I thank God for these gifts: 2005 Mahindra 2615 HST w/loader, (485 hours), and 3710 backhoe. Markham tooth bar, Bush Hog SQ60 rotary cutter, Bush Hog 3507 angle blade, Bush Hog LLR84 landscape rake w/gauge wheels, Rankin loader mounted forks, Paumco Quick Spade, Agri-Ease 3 point log splitter.
  9. #119
    Join Date
    Feb 2012
    Posts
    258
    Sterling, AK
    1026R
    Quote Originally Posted by AchingBack View Post
    I only could see the one. Just asking. I haven't seen one w/o zerks yet- but I'm sure they are out there. Probably Nortrac
  10. #120
    Join Date
    Jul 2009
    Posts
    1,665
    central Wisconsin
    Kubota B7800
    These do not have zerks, the zerks are in the cylinder rod ends and in the loader arm bushing. Massey Ferguson does the same thing with their loader. Kubota does too with the lower pins on the BX series. The middle/upper pin has a zerk. Seems the smaller pins don't have them and the larger pins do, however with the Max they do not although the pins are 1".
Similar Threads
  1. Buying Advice BX25 vs B3030
    By DAT in forum Kubota Buying/Pricing
    Last Post: 03-10-2012, 03:46 PM
  2. BX25 vs GR2020, GR2120
    By GetALoadOfThat in forum Kubota Owning/Operating
    Last Post: 02-03-2012, 09:07 AM
  3. BX25 vs B2626 with backhoe
    By Scooby074 in forum Kubota Owning/Operating
    Last Post: 06-10-2011, 03:50 PM
  4. BX 25 Vs B3000 on hills
    By billhall in forum Kubota Owning/Operating
    Last Post: 04-28-2011, 07:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
