DavesTractor
Elite Member
Started the fabrication of hand controls today. Put a pillar block on the far right side of the foot rest area, bolted solid stock to the shaft and welded the 3/4" steel to the solid stock so there is nothing permanent to the tractor if work needs to be done. Welded a temporary lever to see where the permanent one should go and went out and tried the new toy.
It felt great, even managed to scrounge up a little gravel to scrape up with the bucket. Two problems, the mower deck will not go down and all the lights work except the headlights. It was a mixed day, half happy to be almost ready to go and majorly bummed the deck will not go up and down. Guess I will be seeing how the service is at the dealer. :confused3:
You sound like a handy guy.
Could the mower be latched up? I have not installed a mower on a Max 22 yet (ours will be in this week), but if I recall correctly, you can latch them up so that you can keep them out of the way when you are working the three-point for box scraping or whatever. That way the mower doesn't lower everytime you lower the box. You might check that.
On the headlights, the grill is removed to install the battery during final assembly. I bet the plug did not get plugged in.
