Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Oct 2011
    Gig Harbor, WA
    Mahindra 4035
    Default 4035 Vs. 5010
    Hi all,
    So, after spending the last few months checking the other brands, we've pretty much decided on getting a Mahindra. Mahindra tractors seem the be very well like by their owners (you guys) and have great specs. So the real hard part is deciding which model. The local dealer has both on the lot. The 4035 has the shuttle and the 5010 is gear.
    Pros/cons for both:
    -very heavy for it's size ( 500lbs heavier than the 5010!)
    -12sp shuttle
    -Great reputation
    -Ergonomics (cup holders!)
    -Less power
    -Lower capability implements (loader and backhoe)
    -Higher MSRP
    -Lower MSRP
    -More power
    -Greater capacity implements
    -Larger in size/worse turning radius
    -Higher cost of implements, and probably maintenance costs too.
    -Lighter weight than the 4035
    -Unsure of the reputation of the Korean manufacturer.
    We worked up out the door price quotes today and including for both, loader, backhoe and 5' brush mower. The dealer has had the 4035 for a while and knocked $2k off the price. So now they are about the same price, within $1,500.
    Really for me it's kind of a coin toss. We have 20 acres of rough land that has been cleared by an excavator. Lots of stumps from when it was logged in 2000, lots of brush piles to deal with and firewood logs to skid around.
    We plan on about half to be pasture with the rest being park like with fruit trees and other things that require water and sun.
    It would be nice to have the higher capability implements of the 5010, but once the work is done the land will need just maintenance.
    It's a big purchase of course, and I want to get it right.
    Decisions, decisions!
  2. #2
    Join Date
    Aug 2003
    Welfare Capital of the World...KY
    2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
    Default Re: 4035 Vs. 5010
    Have you considered the 30 series? They're more of a utility tractor but quite a hoss. I'd consider them over the 10 series. You could even find used 00 series tractors.
  3. #3
    Gold Member idaho2's Avatar
    Join Date
    Aug 2009
    SW WA / North Idaho
    Mahindra 5530 4WD Turbo - Gear,
    I agree with jwcinpk, look at the 30 series. With the extra hp your not going to be limited with size of implements. Also, the 30 series are India built. Be sure to have a minimum of two remotes for hydraulic implement needs. Three is even better but that depends on what your future needs are. I have a 5530 Turbo gear and use it on 80 acres.
Similar Threads
  1. Grand L 3940 vs. Mahindra 4035
    By RJJR in forum Kubota Buying/Pricing
    Last Post: 05-09-2012, 09:12 PM
  2. Replies: 22
    Last Post: 12-24-2011, 10:50 PM
  3. Trailer - pros vs cons - leg jack and pipe top
    By ITHINKICAN in forum Trailers & Transportation
    Last Post: 09-02-2010, 03:02 PM
  4. 5 years ago today
    By Tdog in forum Related Topics
    Last Post: 08-31-2010, 10:08 AM
  5. 3320 vs 3520 & hydro vs reverser
    By area123 in forum John Deere Buying/Pricing
    Last Post: 08-28-2010, 02:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
