Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    May 2010
    Posts
    2
    Gloucester, VA
    IH 424
    Default 4025 OR 4010
    Kubota dealer gave me a price of 18K for an L3800F with FEL but I'm not so sure it heavy enough plus don't think FEL is strong enough for what I want if for - Horses and round bales. Just starting to look at Mahindras and thinking the 4025 or 4010 will do everything I want to do with ease. Grew up farming 200 acers with two Farmall M's so I know how the oldies work but these new ones have tons of bells and whisles I've never used... i.e. 4wd - do I really need that if weight is correct??? does 4wd run all the time or is it selectable on/off and use it only when needed i.e. wet/soft barn lot mucking out run-ins etc...
    I've not been having much luck getting any idea of what a good price would be for either of these tractors with a FEL included. Hoping under 20K
    any replies would be appreciated.
  2. #2
    New Member
    Join Date
    May 2012
    Posts
    7
    Ellington, CT
    None
    Default Re: 4025 OR 4010
    Good timing, thanks, I am in the same position. For some reason the dealer is leading me away from the 4025. Not sure why. I am off to get quotes today for 4010 and 4025, and will post what I get. Would appreciate any info & experiences from anyone using a 4025. Thanks!
  3. #3
    New Member
    Join Date
    May 2012
    Posts
    7
    Ellington, CT
    None
    4010 quote local dealer $29,114 with FEL and backhoe. Seems high compared to the deals offered on the Mahindra website? Would appreciate anyone helping compare. Thanks~
  4. #4
    New Member buggieart's Avatar
    Join Date
    Apr 2012
    Posts
    19
    pikeville TN
    huntin
    the 4010 is a tym rebadge to mahindra that may be why is so expensive
  5. #5
    New Member
    Join Date
    May 2012
    Posts
    7
    Ellington, CT
    None
    Thanks, how much is a backhoe for the 4010? I did not get a breakdown of the quote.
  6. #6
    Member
    Join Date
    Nov 2010
    Posts
    39
    London, Texas
    Mahindra 4025
    I've had my 4025 for a little over a year. It has about 65 hrs. on it at this time.
    I wanted an old fashioned tractor (not hydro, etc.) similar in operation to my old 8N. I use it mostly for grading roads and brush removal. It is plenty powerful for my needs. Knowing my central Texas land as well as I do I did not opt for the 4 wheel drive models and have not really regretted having not gotten it. The only problem I've had is recently it developed a small hydraulic leak which I have been unable to isolate myself. I was unimpressed with the dealer when he wouldn't look at the pics I wanted to send him to determine if it was something I could do myself as it is a 100 mile plus trip for me to take it in. He said (without seeing them) that he couldn't diagnose it from pictures. Perhaps, but he could have at least looked at them. As for cost, I paid 14k including
    FEL and filled tires, nothing else. I hope this helps. I would certainly recommend this to a friend.
    RLee
    Mahindra 4025
    JD TrailGator
    Club Car
  7. #7
    New Member
    Join Date
    May 2012
    Posts
    7
    Ellington, CT
    None
    Thanks for responding, sounds like you got a good deal, and great to hear overall positive recommendation for the 4025.
    I got a second quote of 4010, $27,420. Is this normal for 2 dealers to be so far apart ($29,114 first quote posted above). This is for 4010 gear with FEL and backhoe. Feels like my local dealer (higher) is low volume and not very reasonable.
  8. #8
    Member
    Join Date
    Nov 2010
    Posts
    39
    London, Texas
    Mahindra 4025
    I think that difference is about what I got on my pricing. My next up price was 15,700, a little over ten per cent which is about what your seeing.
    RLee
    Mahindra 4025
    JD TrailGator
    Club Car
  9. #9
    Gold Member
    Join Date
    Jun 2010
    Posts
    265
    Grimes county Texas
    Mahindra 4025 / Kubota RTV500 / Bad Boy ZT Elite 60"
    I got my 4025 in May of 2010, $14,600 was drive out with skid steer front end loader. It was a 35 mile delivery to the house, I think most dealers will cover that on a new purchase. I like the 4025 because of it's simplicity, weight, lifting capacity front and back and it's proven design. It is almost identical to the old 400 series Internationals. It still has the distributer port on the right side of the engine block just above the oil filter from the old IH. design for the gasoline option of the tractor. Obviously it is capped off. Like I said just a proven, old, no frills design. Good luck with your purchase.
Similar Threads
  1. 4010 Power Beyond
    By bobsphotos in forum John Deere Owning/Operating
    Last Post: 11-13-2010, 08:14 PM
  2. 4010 ?
    By wilnis in forum John Deere Buying/Pricing
    Last Post: 06-20-2007, 09:52 PM
  3. 2210 or 4010
    By Koz in forum John Deere Buying/Pricing
    Last Post: 03-28-2004, 07:11 AM
  4. JD 4010 Limitations
    By bigpete in forum John Deere Buying/Pricing
    Last Post: 07-03-2002, 10:51 AM
  5. Buying Advice 4010 negotiating advice
    By hazmat in forum John Deere Buying/Pricing
    Last Post: 05-10-2002, 07:51 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
