Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 48
  1. #1
    Join Date
    Sep 2009
    Posts
    1,528
    The County, ME
    Kubota M5640SUD
    Default 4025 4WD sliding or constant mesh transmission?
    Looking at the 4025 4WS features in the online specifications .pdf and it says this machine comes with a sliding mesh transmission but in the tractor comparison tab for the same machine it indicates it has a constant mesh transmission.
    From Wikipedia:
    The earliest form of a manual transmission is thought to have been invented by Louis-René Panhard and Emile Levassor in the late 19th century. This type of transmission offered multiple gear ratios and, in most cases, reverse. The gears were typically engaged by sliding them on their shafts (hence the phrase shifting gears), which required careful timing and throttle manipulation when shifting, so the gears would be spinning at roughly the same speed when engaged; otherwise, the teeth would refuse to mesh. These transmissions are called sliding mesh transmissions or sometimes crash boxes, because of the difficulty in changing gears and the loud grinding sound that often accompanied. Newer manual transmissions on cars have all gears mesh at all times and are referred to as constant-mesh transmissions, with "synchro-mesh" being a further refinement of the constant mesh principle.
  2. #2
    New Member
    Join Date
    Sep 2012
    Posts
    12
    Default
    It's a crash box in that model due to price point pretty sure
  3. #3
    Join Date
    Sep 2005
    Posts
    1,565
    Batavia, NY
    Mahindra -------------
    Default Re: 4025 4WD sliding or constant mesh transmission?
    It is a sliding mesh transmission, basicly 1950's/60's tractor technology. There are no syncronizers in the transmission. It is no big problem on a tractor, as it would be on a car or truck where shifting is done at much higher speeds.
    Galen LaWall
    185 Pearl Street
    Batavia, New York 14020
    585.343.0770
  4. #4
    Join Date
    Sep 2009
    Posts
    1,528
    The County, ME
    Kubota M5640SUD
    Thanks...everyone I've asked this question to agrees on the trans type in the 4025.
    Some suggest these transmissions are more difficult to work with particularly where it involves FEL work. There's a significant cost diff between these and the HST.
  5. #5
    Gold Member ENG18LT's Avatar
    Join Date
    Jan 2012
    Posts
    452
    Syracuse and Warsaw, NY
    Mahindra 5530 4wd
    Default
    If you want a smoother trans for FEL work look at a 4530, 5530, or 6530. They have a shuttle shift 8x8 trans. I can attest to this series trans as being strong, since I have a 5530. Good strong machine. Just food for thought.
    Lee
    Long road home
    Mahindra 5530 w/ FEL, Bushhog 286 cutter, 8' disc, 2 bottom plow, pallet forks, 22' American trailer, geotextile carrier, PHD w/ 12" auger, tooth bar, landscape rake, trailer hitch, broadcast spreader, toolbar, cultipacker, grain drill, and more to come!
  6. #6
    Silver Member ToolBoxTavern's Avatar
    Join Date
    Dec 2010
    Posts
    231
    Texas
    4wd 4025 Mahindra
    I recently purchased one and I have no problem throwing the gear shift into which ever gear I want when doing loader work. It did take a minute to pin point where the gears are, but it is as easy as anything else that has gears as far as I'm concerned. I thought maybe I would be better off with a shuttle shift at first, but this is just fine and I really cant see needing the shuttle shift after using it. I have been busy with umpteen amount of other things and I only have 13+hrs on mine so far. I say go for it!!
  7. #7
    Join Date
    Sep 2009
    Posts
    1,528
    The County, ME
    Kubota M5640SUD
    Thanks TBT...the dealer seemed to really want to talk me out of the manual ... not sure if it was just a matter of opinion or rather had something to do with a bigger sale.
  8. #8
    Join Date
    Dec 2010
    Posts
    231
    Texas
    4wd 4025 Mahindra
    It is a K.I.S.S. tractor and thats all just a tractor. No bells and No whistles. For the price it doesnt get any better.
    K.eep
    I.t
    S.imple
    S.tupid
  9. #9
    Join Date
    Sep 2009
    Posts
    1,528
    The County, ME
    Kubota M5640SUD
    Quote Originally Posted by ToolBoxTavern View Post
    K.eep
    I.t
    S.imple
    S.tupid
    Found a dealer with a 4025 4x4 on the lot. I'm going to test drive it on Sat.
  10. #10
    Join Date
    Dec 2010
    Posts
    231
    Texas
    4wd 4025 Mahindra
    KEWL.
    As far as the shifter goes. Reverse EZ. 3rd and 4th EZ. Now 1st and 2nd I had to find a reference point, but when I did they was easy also. It is bout the steering shaft. There is a warning sticker or some sort of sticker on mine that I cannot recall at the moment right in front of shifter below steering wheel and that is what I use. Now I can get it right in 1st or 2nd without looking.
Similar Threads
  1. 4025 4wd realistic performance
    By michellesc7 in forum Mahindra Buying/Pricing
    Last Post: 08-09-2012, 08:42 PM
  2. price check on 4025 4wd
    By TXMike06 in forum Mahindra Buying/Pricing
    Last Post: 06-27-2012, 07:17 PM
  3. 4025 4wd vs 4035
    By ylr in forum Mahindra Buying/Pricing
    Last Post: 04-24-2012, 10:35 PM
  4. Harming BX 2200 by constant 4WD?
    By carver4591 in forum Owning/Operating
    Last Post: 10-09-2006, 02:11 AM
  5. Constant Mesh...
    By TobaccoRoad in forum Chinese Tractors
    Last Post: 11-07-2005, 08:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
