Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Member
    Join Date
    May 2009
    Posts
    33
    Default 6110 Cab. Is it going to be big enough?
    Looking to replace my old Ford 3000 with a cab and loader with a newer cabbed loader tractor.
    I know the 6110 will be big enough for most tasks but how well will it handle carrying round bales on the front loader. One of my requirements (which my 3000 dose not meet) is the ability to handle a 1200-1400 pound bale on the front loader without ballast other than liquid filled rears. I haul bales front and rear but often I find my feeders frozen in during the winter and need the ability to be able to lift and drop the second bale into the feeder on sometimes less than ideal ground conditions (deep snow/mud) to avoid tearing up my feeders by jerking them out of the frozen ground.
    Having a cab is a must. I have two farms ten miles apart and a cabbed loader tractor each (JD 4020 on the other one) and if one goes down need to be able to road the other one there in any and all conditions to get the stock fed. Thirty below or blizzard conditions make an open station tractor undesirable to say the least in that situation.
    The farm it will be on is the home place and it will be required to feed out right around a 120 rounds a year It also needs to be able to assist in the loading and unloading of the approximately 500 total bales I feed out each year (the rest are used on the other place but I haul need a loader tractor on both ends for hauling). Other uses include bush hogging pastures (eight foot) pulling a v rake and general upkeep around the farm which my ford handles quite well. I like the smaller size of the 6110 and my ford for most uses over my larger 4020 especially for close in work. This tractor will not be needed for the moco or the baler (I also have another open station 4020) that can handle that but with no cab or loader makes a poor tractor for winter feeding.
    I had thought about the 8560 but would prefer to stay with the 6110 both because of price point and storage issues (8560 cab wont clear the barn door on the home place).
    So those of you that have experience with the 6110 do you think it will handle the work ok? Granted the old ford has done if for the last five years since I bought this second farm but it sure could use some improvement on the feeding part and its not built heavy enough in the front end to take the pounding (I have become a pro however at replacing the wheel bearings and keep a set of bearings and seals in stock for it.)
    HST is off the table. I have found that I hate having the brakes on the left side when operating other equipment though I would love to be able to get a hydraulic shuttle trans similar to the one in the 5035.
  2. #2
    Veteran Member AchingBack's Avatar
    Join Date
    Jun 2005
    Posts
    1,593
    Southern Oregon
    Mahindra 2615HST
    Default Re: 6110 Cab. Is it going to be big enough?
    I thank God for these gifts: 2005 Mahindra 2615 HST w/loader, (485 hours), and 3710 backhoe. Markham tooth bar, Bush Hog SQ60 rotary cutter, Bush Hog 3507 angle blade, Bush Hog LLR84 landscape rake w/gauge wheels, Rankin loader mounted forks, Paumco Quick Spade, Agri-Ease 3 point log splitter.
  3. #3
    Member
    Join Date
    May 2009
    Posts
    33
    I know they have the loader capacity. My worry is more along the lines of is the front axle going to be heavy enough in build to not have issues with excessive wear and is the whole tractor going to be stable enough to lift a bale on the front loader without any ballast other than loaded tires. Those are the two main issues I currently have with my 3000 other than the ones relating to its old age. Replacing the wheel bearings on a 4x4 is a bigger job than on the 3000 which takes me about a half hour per side. The stability issue is also a big one for me. Not being able to lift a bale into the feeder with out having another bale or my mower hanging off the back means additional trips into and out of the pasture which is less than ideal and not something I want to have to deal with in a new tractor purchase. At the same time I want to be able to shed the tractor without having to build another building not only because of the initial cost but because they tax me enough as it is.
    My other farm is used mainly for raising beef cattle, however the home place is for my horses, boarding operation, and my horse training and I keep a good number (40 or so) calves on the place of varying sizes for roping, cutting, steer wrestling, and team penning.
    As an aside the smaller tractor is also much better for dragging the arenas, especially the smaller indoor one than the 4020 or other larger tractors could ever hope to be.
  4. #4
    Gold Member ENG18LT's Avatar
    Join Date
    Jan 2012
    Posts
    447
    Syracuse and Warsaw, NY
    Mahindra 5530 4wd
    Default
    If it was me, make the door bigger and get the 8560. You won't ever say I should have gotten the heavier tractor.
    Lee
    Long road home
    Mahindra 5530 w/ FEL, Bushhog 286 cutter, 8' disc, 2 bottom plow, pallet forks, 22' American trailer, geotextile carrier, PHD w/ 12" auger, tooth bar, landscape rake, trailer hitch, broadcast spreader, toolbar, cultipacker, grain drill, and more to come!
  5. #5
    Elite Member
    Join Date
    Sep 2002
    Posts
    2,643
    Red Bluff, CA
    Changes often!
    I think the 6110 is a good size for what you describe. You seem like you are realistic about your requirements and you understand duty cycle. For example, even though the 6110 is rated at 2900 lbs, it really isn't designed to hold 2900 lbs 100% of the time. If it was, it would be a commerical loader like a Cat 928 or whatever, not a multi-purpose farm tractor with loader. But at 50% of rated capacity, I think you will do well with the 6110. It is much beefier than the 6010. Bigger tires, bigger axles, etc. Probably just filling the rears will be adequate ballast, but you always have the option of wheel weights if you need a little more. I find the clutch on the 6110 to be really positive. It is in or it is out. That takes a little getting used to, but also means the clutch should last forever. Not much slipping going on.
    Dave
    Red Bluff, California
  6. #6
    Member
    Join Date
    May 2009
    Posts
    33
    Thanks for your response Davestractor. That is exactly the kind of info I was looking for.
    One other thing that I just noticed when looking at the specs is it mentions that it a partial syncro trans. You wouldn't happen to know which gears have the syncro would you?
    The feedback on the clutch is a good thing in my mind. Did the clutch on my 3000 last year. I would be ok with not having to split another tractor again in my lifetime
    ENG18LT, Your point about the heavier tractor is certainly a valid one. Unfortunately, the area I have to park the tractor in is a lean-too off the end of my indoor arena that will not allow me to go with a larger door due to framing issues. The 8560 would also be a hair to big to get into the horse barn with comfortably (although it would fit) if I needed to.
    Another consideration is the money would have to put out would put me into the territory of a low hour late model cabbed New Holland which would probably be the way I would go in that situation as I do have a decent relationship with the local dealer for that brand.
  7. #7
    Elite Member
    Join Date
    Sep 2002
    Posts
    2,643
    Red Bluff, CA
    Changes often!
    You can upshift through the 4-speed fine, and you can downshift from 4th to 3rd fine, but you can't downshift into 2nd or 1st without nearly coming to a stop. The shuttle is syncho also, so you can engage the clutch and start your forward to reverse gear-change before the tractor is completely stopped. Of course that does not mean it is smart to use the reverser as a brake, it is best to let is stop before letting the clutch back out. Overall a nice shifting transmission and the lack of full synchro isn't really annoying. Since there are several ranges, you won't find yourself shifting back and forth a lot into the lower gears for most tasks.
    Dave
  8. #8
    Platinum Member Reyer Farms's Avatar
    Join Date
    Sep 2012
    Posts
    510
    Lena, ms
    Mahindra 5010
    Default
    For what it is worth: I have 5010 cab, it will pick up your bales no problem, but water in tires is not enough ballast it gets real light. I feel mine is a little lighter than the 6110. I really really like the tractor! It has been great.
  9. #9
    Elite Member
    Join Date
    Sep 2002
    Posts
    2,643
    Red Bluff, CA
    Changes often!
    The 6110 is about 800 lbs heavier than the 5010, but more importantly (concerning stability) the front axle is pushed forward a bit. That moves the fulcrum point and makes things more stable. So we have additional built in weight and a longer wheelbase and less back-wheelies. On the flip side, the 5010 has a really nice tight turning radius due to the shorter wheelbase, but it for sure needs ballast lifting heavier loads.
    Dave
  10. #10
    Join Date
    Sep 2012
    Posts
    510
    Lena, ms
    Mahindra 5010
    Default
    Thanks for the info davestractor! I told my wife this summer the 5010 has been such a great tractor for what we do I wanted to get a second with hst and open station for planting. I was shut down quickly with " no, they have a 6010 now, I think it would be nice to have a larger tractor."
    I do love her.
    Thank you again for sharing about the designs. Does the 6110 have 2 piece wheels in the front with ag tires?
    Jody
Similar Threads
  1. mahindra 6110
    By billyroy in forum Mahindra Owning/Operating
    Last Post: 10-02-2012, 09:59 PM
  2. Tractor Sizing Mahindra 6110
    By HighMileage in forum Mahindra Buying/Pricing
    Last Post: 09-28-2012, 09:22 AM
  3. Buying Advice 5035 or 6110?
    By dhaymon in forum Mahindra Buying/Pricing
    Last Post: 08-11-2012, 04:42 PM
  4. Mahindra 6110 AC Problems
    By KYtwyatt in forum Mahindra Owning/Operating
    Last Post: 05-31-2012, 07:56 PM
  5. takeing cab top off 6110
    Last Post: 05-30-2012, 11:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
