Page 4 of 8 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 73
  1. #31
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    5,956
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    Default Re: Mahindra 100 hp tractor
    No, the 60 series is just plain 12x12 shuttle. No hydraulic shuttle. The 35 series has the hydraulic shuttle option though. Mahindra needs to make just a few more improvements, or at least options and they will be right there with everyone else IMO.
    I REALLY like my Mahindra 7520, but there are times when it would be nice to have a 16x16 tranny. Ah, and a cab with a few more ponies under the hood.
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  2. #32
    Elite Member
    Join Date
    Sep 2002
    Posts
    2,681
    Red Bluff, CA
    Changes often!
    Quote Originally Posted by MtnViewRanch View Post
    How much extra weight do you have hanging on your 7520? More weight means you can now use more HP. You would then add more weight and need more HP. We know your type.....
    I agree on the 16x16. Can't have too many gears or too much power. How does that country western song go? "No girl too pretty, no car too fast?" Applies to tractors as well.
    Dave
    Red Bluff, California
  3. #33
    Elite Member
    Advertiser
    Join Date
    Mar 2005
    Posts
    5,956
    Quote Originally Posted by DavesTractor View Post
    My tractor with no loader is at 10,000lbs. For what I use it for, it is ballasted to the max for the power available. I really need something 100+ hp that weighs 14k+. This would really cut my time down in the fields to be able to use the implements that I now use behind the Cat. There just isn't enough time for all the weekend ranch work.
    Brian
  4. #34
    Elite Member
    Join Date
    Sep 2002
    Posts
    2,681
    Red Bluff, CA
    Changes often!
    You would then just buy more property and need yet a bigger tractor. Face it, there is no end to this.
    Dave
  5. #35
    Elite Member bindian's Avatar
    Join Date
    Feb 2007
    Posts
    3,375
    Willis, Texas
    Mahindra 6520 4WD
    I would love a 100 or 105 hp MAHINDRA with a backhoe that could handle that hp.
    I got a new dual tandem trailer so I can load mind up like Brian's.
    hugs, Brandi
  6. #36
    Elite Member
    Join Date
    Sep 2002
    Posts
    2,681
    Red Bluff, CA
    Changes often!
    Quote Originally Posted by bindian View Post
    hugs, Brandi
    I think Brian's tractor with loader is at nearly 12K lbs, add a 511 backhoe and you are at about 14k lbs. I'd say you would be close to max GVWR even with your tandem dually. I think our tandem dually is rated at 20k on the axles, and we can put a few thousand on the pin. The trailer weighs 7k with the chains and ramps and all, so if we load perfectly we can get about 16K on the deck, but that is maxing the tandems and the rear axle of our pickup. And it is hard to get the axles loaded just as you want them unless you have scales handy.
    Dave
  7. #37
    Join Date
    Feb 2007
    Posts
    3,375
    Willis, Texas
    Mahindra 6520 4WD
    Dave,
    My 511 BH weighs 1600 pounds without a bucket. Buckets are 75-150 pounds or so. The Big RED Beast is 11,300 pounds without loaded tires, with the backhoe. I have no wheel weights. As is......it was 100 pounds under gross weight on my 20 foot 14,000 pound gooseneck. My dual tandem is rated for 22,000 (2000 on the hitch pin, so it is like yours) pounds and weighs 7400 (on the title). I need to take it and weight it for what weight is on the axles, emtpy.
    So now, on paper, I can haul 14,600 pounds on it. So I can add 3300 pounds to the Big RED Beast in weight or attachments or another machine. I bought the dual tandem to haul the grapple AND the loader bucket, as that overgrossed my 20 foot GN by about 300 pounds. The 24 foot deck plus 5 foot dovetail gives me more room to move the load around and balance it out.
    So it seems I could load all 4 tires with rim guard for an additional 1840.4 pounds for a total of 13,140.4 pounds of tire loaded Big RED Beast!
    I have painted marks on the deck of the dual tandem to know where to park the Big RED Beast on it to level it out. Once I know the true emtpy weight on the axles, I will paint on more marks. I also put two white marks on the deck's edge to show where the axles are below.
    Brian, how much in wheel weights do you have on your 7520?
    hugs, Brandi
  8. #38
    Elite Member
    Advertiser
    Join Date
    Mar 2005
    Posts
    5,956
    864lbs of wheel weights (6 sets) and double whatever the std amount is for the front. ( I have forgotten what that amount is. ) I know that it sure is nice to have the loader off and have those front weights on when doing field work. Remember that I also have all 4 tires filled. This is the weight that I have to have to be able to get the maximum capabilities out of the 7520.
    Attached Thumbnails Attached Thumbnails Mahindra 100 hp tractor-p9270003.jpg   Mahindra 100 hp tractor-p5270006.jpg   Mahindra 100 hp tractor-p9270001.jpg   Mahindra 100 hp tractor-p9270006.jpg   Mahindra 100 hp tractor-img_0197.jpg
    Brian
  9. #39
    Join Date
    Feb 2007
    Posts
    3,375
    Willis, Texas
    Mahindra 6520 4WD
    Thanks for the photos and weight amounts, Brian. The New Holland blue paint job still looks good
    hugs, Brandi
  10. #40
    Member musa_marketing2's Avatar
    Join Date
    Oct 2006
    Posts
    32
    Houston, TX
    First look at the new mFORCE tractor. The mFORCE comes with a 5 year warranty standard, like all Mahindras. Sales have been great and owners seem to be very pleased with the new mFORCE tractors.Mahindra 100 hp tractor-mforce-series.jpgMahindra 100 hp tractor-mforce_profile_view.jpg
Similar Threads
  1. 100 HP Mahindra?
    By Farmerboy in forum Mahindra Owning/Operating
    Last Post: 07-11-2012, 11:41 AM
  2. MF 100 series tractor id
    By tsobecki in forum Massey Ferguson Owning/Operating
    Last Post: 10-13-2009, 10:38 AM
  3. 85 to 100 hp tractor suggestions
    By Slippy in forum Buying/Pricing/Comparisons
    Last Post: 11-29-2008, 07:06 PM
  4. MAHINDRA USA. COMMITS $100,000 TO HURRICANE RELIEF
    By tractorErnie in forum Mahindra Owning/Operating
    Last Post: 10-04-2005, 12:38 PM
  5. Best Buy on ~100 hp tractor
    By utahmule in forum Buying/Pricing/Comparisons
    Last Post: 12-08-2002, 11:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
