Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Feb 2013
    Posts
    12
    McComb, Ms
    Farmall 140
    Default 8560 transmission problems?
    Ii have been looking at tractors for a little while now and had finally come up with a decision on the 8560 with a front end loader. Well, I was at the FSA office today filling out the paper work, when I told him what kind of tractor I was wanting to get he seemed concerned. He told me that he had signed off on three mahindra tractors that had transmission issues from pulling a disc. I asked what hp these were and he said 60-70hp range. He said that all these were purchased within a year of each other nearly four years ago. I'm just wondering if any of you have this model and have put them under a heavy pulling load. I'm dont want to spend 32,000 on a tractor that I have to send o the dealership once a year. The main purpose of this tractor is to pull a disc. It's only a 8ft disc but was thinking go getting a 10 ft later on.
    Thanks in advance.
    Dustin
    John Deere 2510
    John Deere 50
    77' Farmall 140
    61' Farmall 140
    Allis Chalmers G
  2. #2
    Gold Member ENG18LT's Avatar
    Join Date
    Jan 2012
    Posts
    465
    Syracuse and Warsaw, NY
    Mahindra 5530 4wd
    Default
    Dave, I don't have an 8560, but can tell you that my 5530 will pull an 8' disc without blinking, in damp loamy topsoil. Hope that helps.
    Lee
    Long road home
    Mahindra 5530 w/ FEL, Bushhog 286 cutter, 8' disc, 2 bottom plow, pallet forks, 22' American trailer, geotextile carrier, PHD w/ 12" auger, tooth bar, landscape rake, trailer hitch, broadcast spreader, toolbar, cultipacker, grain drill, and more to come!
  3. #3
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    5,898
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    Default Re: 8560 transmission problems?
    When you guys say how wide the disk is that you want to pull or are pulling, what type of disk, what size of blades, how heavy all make a HUGE difference.
    Here's an 8' Kello-Bilt unit that none of Mahindras tractors will pull. Except with the wheels down maybe.
    I have a 7520, about 600 hours on it, no tranny problems, no problems at all really. Ballasted to a bit more that 10,000lbs without the loader and on rolling terrain my old 8' Kelfer offset disk is all it wants. This is a disk with 22" blades and weighs about 2600lbs-2800lbs. I would forget about a 10' disk if it were me. But then when I disk, I am usually 8-9" in the ground.
    Attached Thumbnails Attached Thumbnails 8560 transmission problems?-img_0197.jpg   8560 transmission problems?-p3190008.jpg   8560 transmission problems?-p2090021.jpg   8560 transmission problems?-p2090015.jpg   8560 transmission problems?-img_0207.jpg
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  4. #4
    Bronze Member Mobass's Avatar
    Join Date
    May 2012
    Posts
    76
    Lebanon, MO
    Mahindra 8560
    Funny how he signed off on these tractors when they have a 5 year power train warenty??? I have a 8560 I use. I don't pull a disc with it. But what ever I have thrown at it, It has done the job with NO problems.
  5. #5
    Elite Member
    Join Date
    Sep 2002
    Posts
    2,653
    Red Bluff, CA
    Changes often!
    Quote Originally Posted by Sideoutds View Post
    Thanks in advance.
    Dustin
    Doesn't sound correct. The 8560 has a strong transmission. The only failure we have ever seen ourselves is due to lack of fluid. We had a farmer that was running a big hydraulic implement and blew a hose and did not know it as the implement was behind him and he wan't paying much attention. He ran the transmission dry before he knew it and toasted the bearings that support the upper shaft since they were then completely dry and no transmission can run that way. The 8560 is a good strong tractor. I'd certainly question the FSA guys memory or perhaps even his motives.
    Dave
    Red Bluff, California
  6. #6
    New Member
    Join Date
    Feb 2013
    Posts
    12
    McComb, Ms
    Farmall 140
    Default
    I had talked to the salesman whom happens to be the owner of the dealership I'm buying from and he seemed pretty agitated that the loan officer had said that. He assured me that the transmission wasn't an issue. I will be going forward with my purchase. I also didn't come across any threads with transmission failure as a theme.
    Thanks
    Ds
    John Deere 2510
    John Deere 50
    77' Farmall 140
    61' Farmall 140
    Allis Chalmers G
  7. #7
    Join Date
    May 2012
    Posts
    76
    Lebanon, MO
    Mahindra 8560
    I belive you will be very satisfied in your descion. Will be interasted in how it does for you. Keep us posted.
Similar Threads
  1. BX 23 Transmission Problems
    By rickoshay in forum Kubota Owning/Operating
    Last Post: 04-20-2012, 07:22 PM
  2. transmission problems
    By sharpanther in forum Parts/Repairs
    Last Post: 10-29-2011, 07:21 PM
  3. Transmission Problems???
    By Surfmonkey in forum Craftsman / Sears
    Last Post: 09-06-2011, 12:49 PM
  4. transmission problems
    By garydc in forum Parts/Repairs
    Last Post: 10-09-2007, 08:09 PM
  5. Transmission problems
    By carman in forum John Deere Owning/Operating
    Last Post: 10-16-2005, 08:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
