Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Jul 2013
    Posts
    1
    Parkers Prairie ,MN
    IH 464
    Default 4035 vs1040 Mcormick
    Trying to decide witch tractor to buy. Have a McCormick dealer just down the road from me and know a couple of the guys that work there that have said the McCormicks don't come into the shop to often. The Mahindra looks a little beefer. They both have good a bad. Just looking for some input. thanks.
  2. #2
    Elite Member JerryK's Avatar
    Join Date
    Feb 2004
    Posts
    2,635
    Vanderbilt, Michigan, USeh?
    Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST
    Default Re: 4035 vs1040 Mcormick
    Don't know much about the Mcormick tractor. But the 4035 and 5035 tractors are basicaly a utility size tractor, so it is hard to compare them with a lot of tractors from other manufactures that have mostly compact utility tractors in that horsepower range. If you are going to be trailering the tractor, these 35 series Mahindras usually weight one or two thousand pounds heavier than the other tractors in the horsepower range. So it is mainly like comparing apples to oranges... Enjoy looking, and take your time to make your decision...
    PS: The Mahindra 10 series, like the 4010 or 5010 are probably simular to what you are looking at in the Mcormick. The 35 series are big heavy bastardo's.... that's why I have one. I got frustrated in my about 5100 pound JD 2240 sometimes trying to horse stuff around. So, the 5035 was a big step up in moving ability, but about a ten horsepower drop in motivation. 5035HST weights in over four tons with the FEL and backhoe on... Depends on what you are going to want to do... that's why you should spend lots of time looking.
    78" [26"X10"fan] Mahindra front blower,72" Mahindra front blade, 48" CID QA forks, 6' EverythingAttachments Land Plane & Landscape Rake, 78" JRW rear blower[26"X8"fan], homemade 1 ton rear weight, 6' Ford rear blade, big homemade 3pt box/carrier, 8" wood chipper
Similar Threads
  1. new 4035
    By landman in forum Mahindra Owning/Operating
    Last Post: 08-01-2012, 10:12 PM
  2. 4035 Pic
    By Chris 3055 in forum Mahindra Owning/Operating
    Last Post: 05-13-2012, 11:00 AM
  3. 4025 4wd vs 4035
    By ylr in forum Mahindra Buying/Pricing
    Last Post: 04-24-2012, 11:35 PM
  4. Chains 4035
    By hydro2 in forum Mahindra Owning/Operating
    Last Post: 01-25-2012, 12:15 PM
  5. 4035 FEL & BH??'s
    By Punk in forum Mahindra Buying/Pricing
    Last Post: 06-17-2009, 03:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
