Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Jun 2014
    Posts
    2
    Lenox MO
    IH 444
    Default 5035
    Looking to buy a new or newer tractor. Looked at several different brands and I always end up liking what Mahindra offers. Looked at the 4530, 5035, and 6530. the 6530 is not available in tier 3 around here any longer and it may be too big for what I am looking for. I really like the way the 5035 feels. does anyone have any experience with the 5035?
    It will be used on a small farm for hay cutting and bailing and chores around the farm. Any input would be greatly appreciated.
  2. #2
    Veteran Member AchingBack's Avatar
    Join Date
    Jun 2005
    Posts
    2,181
    Southern Oregon
    Mahindra 2615HST
    Default Re: 5035
    What transmission are you looking at in the 5035. Three types are available. I found reviews for some of them. Mahindra 5035 PST Reviews - TractorByNet.com Mahindra 5035 Shuttle Reviews - TractorByNet.com
    Here is a link to some discussion threads on the 5035, Search Results - TractorByNet.com
    I thank God for these gifts: 2005 Mahindra 2615 HST w/loader, (485 hours), and 3710 backhoe. Markham tooth bar, Bush Hog SQ60 rotary cutter, Bush Hog 3507 angle blade, Bush Hog LLR84 landscape rake w/gauge wheels, Rankin loader mounted forks, Paumco Quick Spade, Agri-Ease 3 point log splitter.
  3. #3
    New Member
    Join Date
    Jun 2014
    Posts
    2
    Lenox MO
    IH 444
    Default Re: 5035
    The closest dealer is only 10 miles away. He has the 5035 PST on his lot at the current time. I would just prefer the shuttle shift.
  4. #4
    New Member
    Join Date
    Apr 2014
    Posts
    15
    Moulton, al
    Belarus, allis chamlers, yanmar
    Default Re: 5035
    Good luck in your hunt! I have a 5035, only had it a couple of months and have not used it as much as I would like. Travel and family has kept me away alot. I have developed a couple of small leaks already, just a drop or two each time I use it. I have a rubber mat under mine and I notice a drop or two each time. I have developed a hesitation in the curl down of the bucket when close to idle. I have not had a chance yet to speak to the dealer about it. Another poster on here is having the same issue. Other than that, the tractor is a beast! I stuck a 70 hp tractor with a cab, I should say I buried it! The 5035 pulled it out and didn't even spin a tire. The tractor that was stuck weighed 9000lbs!
    I only have 19 hours on mine so not alot of experience. If it hold up and I don't have alot of problems I think I am going to like it.
  5. #5
    Veteran Member JerryK's Avatar
    Join Date
    Feb 2004
    Posts
    1,281
    Vanderbilt, Michigan, USeh?
    Mahindra 5035, JD 2240, 420
    Default Re: 5035
    I have a 2011 5035 HST. Only leak I have ever had was a drop on a banjo fitting on the loader control valve assy. Put a wrench on it right after the dealer dropped it off and took care of that. Only mechanical problem I have had, if you can call it a problem, is that I had to tighten the fan/alternator belt at about 100 hours when drawing a heavy lighting load playing out in the snow. Used it yesterday to do a final lift and paint of the bottom of my 500 gallon propane tank. No fuel line problems/hose cracks/etc.
  6. #6
    New Member dukeyjoe's Avatar
    Join Date
    Jul 2014
    Posts
    12
    Bryant, Al
    Mahindra 5035 HST; Long 2610
    Default Re: 5035
    I am in the process of buying one as we speak. Would like to know what price they are shooting you. There are not too many to be had. My dealer is going to have to go out of state to get one for me.
  7. #7
    Bronze Member Bascom's Avatar
    Join Date
    Feb 2007
    Posts
    95
    Savannah, Georgia
    2010 Mahindra 5035
    Default Re: 5035
    My 2010 5035 shuttle rocks! Would buy it again in a heartbeat. Just under 300 hours so far on it.
    The dealer I bought from, Lott Enterprises in Claxton, GA is excellent as well.
    2010 Mahindra 5035 w/FEL and a bunch of attachments.
Similar Threads
  1. My new 5035
    By Dougw133 in forum Mahindra Owning/Operating
    Last Post: 04-05-2012, 02:27 AM
  2. Comparison 5035 vs 5530
    By wbuoni in forum Mahindra Buying/Pricing
    Last Post: 07-24-2011, 12:40 PM
  3. 5035???
    By gumshu in forum Mahindra Buying/Pricing
    Last Post: 05-18-2011, 12:34 PM
  4. Buying Advice 5035
    By the6shooter in forum Mahindra Buying/Pricing
    Last Post: 02-17-2011, 12:35 PM
  5. New 5035
    By Bascom in forum Mahindra Owning/Operating
    Last Post: 11-10-2010, 05:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
