HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
LinkBack Thread Tools Display Modes
Old 02-04-2008, 06:20 PM   #1 (permalink)
Member
Location: 15 acres Celeste, Tx 465 acres Hamilton Co., Fl
Default 6500 4WD rear hyd. leaking down
35 hours and even with a light weight rear attachment like post hole diggers without auger (maybe 220 lbs) it will drop about 1 ft per 2 hours. FEL is fine. Can find no leaks and fluid is good. Any thoughts?
__________________
Arnold
6500 4WD
SKR165 Loader
Massey Ferguson 1080
Bush Hog Back Hoe
Howse 70" Tiller
Atlas 72" disc
King Cutter 72" Bush Hog
Euroc 1000 lb spreader
Howse Subsoiler/Middle Buster
2 Bottom Plow
awill99 is offline   Reply With Quote
Old 02-05-2008, 04:11 AM   #2 (permalink)
Member
Default Re: 6500 4WD rear hyd. leaking down
Maybe an internal seal?
__________________
THINK BEFORE TALKING
MASSEY FERGUSON 65 GAS (unbelievably reliable tractor)
MASSEY FERGUSON 1433 W/ a woods 1012 FEL.
PAST TRACTORS (RIP)
FORD 3000 (great tractor)
FARMALL 350 W/ T/A
toddol1971 is offline   Reply With Quote
Old 02-05-2008, 11:14 AM   #3 (permalink)
I had a similar problem. It eventually got to the point where, with an attachment on back, the draft arms would fall when I used the loader. It turned out that one of the rings (hard plastic) on the draft arms cylinder was flattened (had rolled out of groove). As soon as hydraulic pressure was diverted to the loader (and away from the draft arm) fluid would leak between the cylinder and the cylinder wall.
Bob
Bobvt is offline   Reply With Quote
Old 02-06-2008, 08:00 PM   #4 (permalink)
New Member
BigTy's Avatar
Send a message via Yahoo to BigTy
Hey Arnold! I'll bring up your problem at work tomorrow, and see if we can figure anything out. May have to get hands on it. I still have your cell #, I'll give you a call tomorrow. By the way, how you been?
Ty
__________________
uva uvum vivendo varia fit
BigTy is offline   Reply With Quote
Old 02-06-2008, 08:10 PM   #5 (permalink)
warranty!
SPYDERLK is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
