HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 12-17-2007, 08:48 PM   #1 (permalink)
SABULA FARMER's Avatar
Default 2615 Ticking sound
Hello all,
I have a question in reference to my 2615, I noticed the other day when I was plowing some of this snow we just received, after the tractor warmed up a bit, it started ticking. I can't say exactly from where but it sounds like its comming from the engine...any ideas? I don't beleive its a valve, the engine runs great and has plenty of power...
SABULA FARMER is offline   Reply With Quote
Old 12-18-2007, 08:23 AM   #2 (permalink)
Epic Contributor
Bird's Avatar
Default Re: 2615 Ticking sound
Does it only happen after it's warmed up? And is it only when it's moving, or when it's sitting still? The only "ticking" sound I had to hunt on my B7100 Kubota turned out to be the hour meter, which was simply an electric clock that ran any time the key was turned on, whether the engine was running or not.
__________________
Bird is offline   Reply With Quote
Old 12-18-2007, 09:19 AM   #3 (permalink)
hst or gear?
bkheur is offline   Reply With Quote
Old 12-19-2007, 08:21 AM   #4 (permalink)
I really don't have any idea where your ticking sound is coming from, but I would try unhooking the hour meter cable from the engine and see if the sound goes away. Just something to try. Good luck!
__________________
Galen LaWall
Your Mahindra Tractor Dealer
185 Pearl Street
Batavia, New York 14020
585.343.0770
LAWALLSTRACTOR is offline   Reply With Quote
Old 12-19-2007, 02:23 PM   #5 (permalink)
Quote:
Is the hour meter cable sealed? I know if you disconnect the cable on a truck or car it voided the warranty (or at least it did when I was in the business). Will disconnecting it void the warranty on the tractor? On a car it could only be done by the dealership and they needed to record it to keep the warranty in place.
Something to think about.
Don
__________________
Country Life Beats Working.
Less than 5 years to Retirement
DonWorrell is offline   Reply With Quote
Old 12-19-2007, 07:15 PM   #6 (permalink)
Okay fellas, I have some information to pass along. I am not happy over the news that I got today on this "ticking" noise however I was informed it was loose valves. The tractor is less than a year old, 11 months to be exact, and it only has 73 hrs on it. Now is this normal for the valves to need adjustment after that short period of time..? If so I am concerned for the longevity of the tractor.
S.F.
Old 12-19-2007, 10:18 PM   #7 (permalink)
S,F.
I have sold a lot of 2615's since they first came out and I have yet to adjust the valves on one, so I know it is not common. Have your dealer check it out well when he adjusts them, to make sure something isn't wrong causing the misadjustment. Probably just adjusting the valves properly, will solve the problem and it will not need to be repeated for a long time. Good luck with it!
__________________
Galen LaWall
185 Pearl Street
585.343.0770
Old 12-19-2007, 10:22 PM   #8 (permalink)
I have 105 hrs on my 2615 and everything it still working great. No ticking sounds
Old 12-19-2007, 10:56 PM   #9 (permalink)
S,F.
That is what I was thinking about the valves. I dont know why they went out of spec. What other kind of problem could make this happen? Anything serious...? Is this something that Mahindra will cover and should they be informed of it?
Old 12-19-2007, 11:14 PM   #10 (permalink)
Could you give us a little more detail on the ticking sound?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
