HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-08-2008, 09:51 AM   #1 (permalink)
New Member
Location: Schriever, Louisiana about 55 miles sw of New Orleans
Default 475 Di early Models
I have a 475 Di. It has a 3 cylinder engine. My question is online I find 475 Di with 4 cylinder engine why and when did they change to 4 cylinder engines?
I also found out that the PTO speed runs at different speeds according to high and low transmission settings instead of engine speed.
I like this little tractor I can work it all day on a cup full of fuel.
Thanks
seaplanepilot1 is offline   Reply With Quote
Old 06-09-2008, 10:39 PM   #2 (permalink)
Member
Default Re: 475 Di early Models
I don't know when they changed the 475 Di to the 4 cylinder motor, but I am curious if you have the same 3 cylinder motor that is in the later 350 Di. I have a 350 Di, and that is a strong tractor. I use it mainly for bush hogging and plowing a 3.5 ac field. You can't even tell that the 5' bush hog is behind you. It'll also run all day without a single compliant.
Regarding the PTO, you may want to get advice from a dealer or from Mahindra. With the 350 Di, you are not supposed to run the PTO in the high range.
jlinskey is offline   Reply With Quote
Old 06-13-2008, 09:39 PM   #3 (permalink)
New Member
I have a manual for the 475DI, 485DI, and 575DI, dated August '98. It shows the 475 with a three cyl. engine. If they changed, it was after the manual was published. There is a PTO speed selector on the left side of tractor below the clutch pedal. It has a Hi, Lo, and neutral. All brush cutters are intended to run on the low setting, as are all PTO driven equipment (as far as I know). The lo PTO speed is 540 rpm@2058 engine rpm and hi PTO speed is 1000 rpm@ 2043 engine rpm. Hope this helps.
Old Pop is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
