This week I finally got to put the 5525 through some tough tasks. A past windstorm blew over some fairly large trees, thr biggest a 75 yr old spruce wit a 4.5 ft diameter that ended up in acreek. We got a log miller to respond, but my son and I had to recover the trunks and haul it up to him. We ended up with 9 sections, some as lng as 20'. The portable mill could only handle tunks up to 4500#. We had to use at times my Massey to assist pulling 20' trunks up hill out of the creek as the wheels on the Mahindra began to dig holes as the creek bed was rather soft. Anyway, with 18 hrs on the clock and some rather straneous tasks perfomed the Mahindra never missed a beat, did not cut out or smoke. I checked the timing marks and it is right on even so did not bother to do the slight advance as it was not needed.
So whatever the one time incident with smoke and missing was, di not happen aggain. Perhaps some contaminant in the fuel that passe through and now is gone.
The only anoying thing is the shifting. At dead dtop, the gears still have some problem engaging without some grind. I checked the free play and it was in specs.The book calls for 1/2" of free peddal. If I double clutch, sometimes it helps. Sometime shifts ok and at time no matter how careful, still grinds and fuel consumption is more than the Massey for the same running time. I can run the Massey, bush hogging for 7 hrs at 1400 rpm and about 3 gal. I think if I can get the idle down to 750-800 the shifting would bee smoother.I know it is set at factory to 900 and will see if lowering it is possible.
