HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-15-2008, 01:41 AM   #1 (permalink)
Gold Member
Default 2015 3PT stuck in the "up" position
I've noticed recently it was difficult to lower without really pushing hard one the lever.
Today I raised a loaded 3PT attachment, however it wouldn't lower. After tapping on lever near the pivot point, I could get it come down. The lever operated normally when raising it.
I'm waiting until Monday to talk to my dealer.
Has anyone seen this?
srjones is offline   Reply With Quote
Old 06-15-2008, 07:28 AM   #2 (permalink)
NEFirewood's Avatar
Default Re: 2015 3PT stuck in the "up" position
Have you tried adjusting the 3 point speed control below the seat? I've had to adjust mine after I bought it because it was set to go down too slowly for me.
NEFirewood is offline   Reply With Quote
Old 06-15-2008, 04:35 PM   #3 (permalink)
Gold Member
Yeah, I've done that. Once the lever is in the down position, the 3PT will lower. The issue is getting the lever there in the first place.
Old 06-15-2008, 10:39 PM   #4 (permalink)
Gold Member
AchingBack's Avatar
The lever was very stiff on my 2615 3PT. There is a rod connected to the lever. The connection uses two nuts. I loosened, and adjusted the nuts, and the lever began to move freely. I believe the inner nut it too tight against the linkage rod. I don't know how it is on the 2015.
__________________
I thank God for these gifts: Mahindra 2615 HST w/loader, Markham tooth bar, Brush Hog SQ60 rotary cutter, Brush Hog 3507 angle blade. Rankin loader mounted forks, 2 DR field and brush mowers
"Blame no one. Expect nothing. Do something".
-- Unknown
AchingBack is offline   Reply With Quote
Old 06-16-2008, 12:10 AM   #5 (permalink)
Gold Member
At first I was thinking it was something like that but the wierd thing is that once I tap it with a hammer to get into the down position, I can pull it back to the up position with normal force.
Anyway, I'll post back once I talk to the dealer.
Thanks....
Old 06-17-2008, 02:18 AM   #6 (permalink)
Gold Member
Problem solved!
I talked to Steve Roy at Valley View Tractor in Newberg, Oregon and he thought it be a stuck linkage issue probably due to rust. He suggested giving it a good dose of penetrating oil, letting it sit and then working it back an forth until it's back to normal.
And I did just that. However, I couldn't find my can of PB (PowerBlaster) so I used Fluid Film which worked just as well (and smells much better). And now the 3PT works better than it has in a long time.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
