HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 08-07-2008, 03:52 PM   #1 (permalink)
New Member
Default 4110 frt axle nosiey
axle makes clicking rubbing sounds, fluids all full, 4wd works fine. could it be something easy?
rickard45 is offline   Reply With Quote
Old 08-07-2008, 11:04 PM   #2 (permalink)
Default Re: 4110 frt axle nosiey
Check the bolts that bolt the front axil to the tractor frame. They have been know to loosen and when the axil shifts a little the drive shaft will act like what you are explaining. Check this soon before things get worse.
__________________
Galen LaWall
Your Mahindra Tractor Dealer
185 Pearl Street
Batavia, New York 14020
585.343.0770
LAWALLSTRACTOR is offline   Reply With Quote
Old 08-07-2008, 11:34 PM   #3 (permalink)
New Member
thanks for the info, the bolt were loose a year ago or so. will check to see if it has shifted, i have done a lot of dirt work on a 30 by 40 shop that i built.i rased the the tractor with the loader and spin the tires the the whole axle assy sounds nosiey is this normal
Old 08-09-2008, 01:53 PM   #4 (permalink)
Gold Member
When mine is all in good condition there is very little noise when turned by hand slowly. You can always hear a little gear mesh and/or a little slop if rocked back & forth but no growling or grinding. This is all assuming you're not trying to spin the wheel at 30 mph - 3 times as fast as it's supposed to be going. The drivetrains are much more forgiving of minor wear & tear simply because of the speed that they operate. I've had my share of front axle problems, you can review my posts over the past 4 years.
__________________
Mahindra 4110, FEL w/5' & 6' QA buckets & forks, 6' Atlas boxblade, 6' Howse rotary, Leinbach PHD w/9" & 12", 1 bottom plow, MF 2/3 bottom plow, 20"x6' bog disc,TSC subsoiler, TSC middlebuster, 6 ton Anderson 12' dump trailer, 20' Hurst 14k flat trailer.
skipmarcy is offline   Reply With Quote
Old 09-13-2008, 10:35 AM   #5 (permalink)
We have a noisy 4110 in the shop now and it had a few teeth missing on the front ring & pinion . Make sure you use enough counterweight when using the front loader because you want the rear axles doing at least 75% of the work not the front .
Poboy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
