Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Mar 2009
    Posts
    2
    Default 4025 fuel use
    I am thinking about purchase of a 4025 with FEL that will allow Bobcat attachments to be used, I don't see the 3525 as having that flex. In what I have read, the fuel use of the 3525 is very low at least while hogging at about 1 gal per hour.
    Do those of you that have experience in the use of the 4025 consider the fuel use similar with the extra 5HP? I know it is a different engine. If anyone can compare it also with the 5525 I would appreciate that as well. Thanks, I have enjoyed reading the forum. joe
  2. #2
    Super Member bindian's Avatar
    Join Date
    Feb 2007
    Posts
    6,944
    Willis, Texas
    Mahindra 6520 4WD
    Default Re: 4025 fuel use
    Quote Originally Posted by joebdot View Post
    I don't know about any of those models. But my 6520 drinks about a gallon an hour. Unless I am backhoeing at full throttle.
    hugs, Brandi
  3. #3
    Member
    Join Date
    Feb 2008
    Posts
    39
    Beggs OK
    1946 Ford 2N
    my 3525 uses about 1 gal/hr brush hogging 3rd gear low range.... I only have 5 acres, with trees and ponds... can't get going too fast.
    as far as the quick attach bucket I believe that is a dealer installed option available on all of the loaders, not sure though.
    Mahindra 3525 w/ loader
    Ford 2N
    many attachments
  4. #4
    New Member
    Join Date
    Aug 2007
    Posts
    13
    Central Maine
    Mahindra 5525 Allis Chalmers D14 & D15
    I would guess fuel use would be similar. Our 5525 has 220 hrs and has used 220 gallons of fuel give or take a gallon or two. It's used with a mower- conditioner, baler, and snowblower at 2000(540 pto)rpm and between 1500 and 2000 rpm for loader work. It spends about 15 minutes a day in the wintertime idling while I shovel horse manure into the bucket. That's about it for regular usage.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
