HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-11-2009, 01:52 PM   #1 (permalink)
Gold Member
Default 3325 with 78 hours won't start
My 3325 will be 3 years old July 2009. I put a new battery in the tractor a month ago. I put in what was called for by the manufactor. It started and ran well.
I went out last evening and tried to start it. I put everything in netural turned on the key all the lights turned red as they should. It turned over once or twice or about 2 seconds then it went dead. All the lights and gagues are dead.
What could possibly be wrong?
Don
__________________
Country Life Beats Working.
Less than 4 years to Retirement
DonWorrell is offline   Reply With Quote
Old 06-11-2009, 04:03 PM   #2 (permalink)
Sergei's Avatar
Default Re: 3325 with 78 hours won't start
How about your head lights, do they come on? You might also have your battery checked at some auto store under a load to make sure it's still good and how about the battery connectors are they good? Really sounds light a dead battery or one that's not being recharged correctly. Have you measured the battery?
__________________
Sergei
Mahindra 2815 HST FEL, KK 5' Rotary Mower ,5' Box Blade
Vinton, Ia
Sergei is offline   Reply With Quote
Old 06-11-2009, 05:39 PM   #3 (permalink)
Dead Battery, check connections, give it a charge and see what happens.
__________________
Geaux Tigers
________________________
Mahindra 2816 gear w/loader, 5ft Woods Heritage Cutter, 5ft Atlas Angle Blade
duckhunt is offline   Reply With Quote
Old 06-11-2009, 06:10 PM   #4 (permalink)
Elite Member
flusher's Avatar
Don
Battery not charging is my guess.
Why?
Bad cell (it happens occasionally with new batteries--infant mortality).
Problem in the battery charging circuit -- blown fuse, alternator problem, voltage regulator.
Put the battery on a charger for 24 hours and see if you can get started. If not, take the battery back and get it tested. Should be under warranty.
flusher is offline   Reply With Quote
Old 06-11-2009, 07:31 PM   #5 (permalink)
First check the battery connections at both ends of the cables.
__________________
Galen LaWall
Your Mahindra & TYM Tractor Dealer
185 Pearl Street
Batavia, New York 14020
585.343.0770
LAWALLSTRACTOR is offline   Reply With Quote
Old 06-12-2009, 09:24 AM   #6 (permalink)
New Member
I agree with Galen. If the battery and connectiions chek to be in good working order, it could be the 30 amp "Max Fuse". If this fuse is blown, it would cause the same symptoms that you are experiencing.
Scott@Artec
721h354 is offline   Reply With Quote
Old 06-29-2009, 12:15 PM   #7 (permalink)
Gold Member
I found he problem. I left the head lights on. I put a trickle charger on the battery. After the battery charged the tractor started right up. It has started everytime since.
The 3325 is still a problem free machine. Operator error is the only problem I have had in three years.
Don
__________________
Old 07-01-2009, 01:31 PM   #8 (permalink)
Midsouth's Avatar
yep sometimes it is the simple things that get you
Midsouth is offline   Reply With Quote
Old 07-02-2009, 11:26 PM   #9 (permalink)
xlr82v2's Avatar
Don,
Are you sure that's the problem? On my 3525 (2007 model), all of the lights go through the ignition switch... nothing's on the "hot bus", so to speak. I would assume (but I know what happens when you do that ) if you turned the key off, the lights should have gone out as well. I would think that with the 3325 and 3525 being so similar, the wiring would be identical. But, maybe not.
And, 78 hours in 3 years? Get out there and work that thing!!
__________________
Brian
2007 Mahindra 3525
1952 Ford 8N
xlr82v2 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.20003 seconds with 8 queries
