HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 07-01-2009, 08:53 PM   #1 (permalink)
Tim Stuart's Avatar
Default 575 Di Hydraulic control Valve Assembly
Need some help. I have a 1994 575 DI Mahindra tractor that I have broken a valve off of the Control Valve Assembly. The hydraulics are still working on the tractor but they are slow and sometimes they are unresponsive. It is leaking hydraulic oil where the valve stem would be, First what does this valve do? and would it be better to replace the entire Hydraulic Control Valve assembly or just the broken Valve. I am not sure if I can even get the parts. I contacted a couple of dealers and I was told the parts were manufactured discontinued. They did say if they did have the parts that they would be expensive, The complete hydraulic assembly would be in the neighborhood of $550 and the valve would be about $60 How hard would it be to just replace the broken valve? Thank you for your thoughts.
Tim Stuart is offline   Reply With Quote
Old 07-02-2009, 09:59 PM   #2 (permalink)
Member
Default Re: 575 Di Hydraulic control Valve Assembly
Shouldn't be a big deal to replace. Mahindra shows to have that valve assy. on hand at the parts depot. Your local dealer should be able to get you one for around 50 bucks or so.
YellCoGin is offline   Reply With Quote
Old 07-03-2009, 09:42 AM   #3 (permalink)
Tim Stuart's Avatar
Quote:
Thanks, Do you have any idea what the valve is used for? I have had the tractor for about 5 years now and have never touched it. I had a stick pop up from the ground and break the valve stem and handle off.
Old 07-03-2009, 07:27 PM   #4 (permalink)
It controls the rate of drop on your 3PH.
__________________
Galen LaWall
Your Mahindra & TYM Tractor Dealer
185 Pearl Street
Batavia, New York 14020
585.343.0770
LAWALLSTRACTOR is offline   Reply With Quote
Old 07-09-2009, 02:00 PM   #5 (permalink)
New Member
Quote:
It is amazing how much stuff can get broken just from relatively small sticks popping up when you drive over them.
consaka is offline   Reply With Quote
Old 07-12-2009, 07:04 PM   #6 (permalink)
If (on the diagram) knob #14 controls the 3PH rate of drop, what does the knob on the other side (#26) control? It says "FAST" and "SLOW," so I thought that controlled how fast the 3PH moved. Mine seems to leak fluid from #26. What am I missing?
485didriver is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.25904 seconds with 8 queries
