Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 07-07-2009, 07:50 PM   #1 (permalink)
New Member
Default 5500 leak?
Has anyone else had a leak in the power steering box? this is the one that the steering wheel attaches to by 3 bolts and has 3 tubes coming out? the valve? is under this on top of frame. The bolts are tight but it has a slow persistent oozing leak that makes a mess and depletes the resovoir.question is? does it have a gasket? or is it "blue goop" gasket? I have tightened as best I can without stripping it. thanks for info!
ricky1 is offline   Reply With Quote
Old 07-08-2009, 12:53 AM   #2 (permalink)
Default Re: 5500 leak?
Remove the dash panel and look at the steering box from the top. There may be a allen head plug in the top of the box that may be loose. I hope this helps.
__________________
Galen LaWall
185 Pearl Street
Batavia, New York 14020
585.343.0770
LAWALLSTRACTOR is offline   Reply With Quote
Old 07-09-2009, 01:39 PM   #3 (permalink)
New Member
Thanks Galen, but the culprit is at the 3 bolt pattern plate at the bottom of the steering column . the pump is attached by these 3 bolts. I have wiped down all the area and continue to see seepage from one bolt hole or the seam of the part? Can't really tell as it spreads? I will try some gasket goop and see if the bolt thread is causing the seepage.Found out that the pump is a BIG ticket item so I dont want any problems with it [550$]I talked to a Mahindra CR on the chat line and they didn't have any idea about what I was talking about? Finally said it was beyond his capability to give me an answer? One thing is Mahindra should make available some basic diagrams or parts blow ups[ie. JD!] to help to find problems? would make a valuable aid to those of us who use their product.o----------I also "consulted" with a parts person at the closest dlr to me and they said the same thing?that they didnt have any microfiches or blow ups of parts? just what was on the manual and it wasnt much?what do they do if they have something major mess up? oh well? its mowing season and I have a down tractor to fix and make a living. Thanks for your input!rac
Old 07-09-2009, 10:17 PM   #4 (permalink)
Member
That manifold is held on to the steering motor by the three allen head bolts. Mahindra sells the motor and manifold as a unit but I think there is some orings between them that could be replaced. Make sure those allen bolts are tight before jumping in to far. Hopeful just a turn of a wrench might take care of it. Be careful with that gasket goop if it gets inside the system you could be in big touble.
Good luck
Dave
YellCoGin is offline   Reply With Quote
Old 07-10-2009, 08:26 PM   #5 (permalink)
New Member
Dave Thanks, I tried tightening the 3 bolts,they are tight! no allen head seen tho? these bolt heads are about 5/8.I am wondering if vibration or the flexing of tractor when mowing is causing the leak?I wish Mahindra had a decent blow up picture of parts so that a person could see what they are getting into? It ain't rocket science?went and checked today after I sealed the edge and dabbed the blt head with the silicone sealer and as usual---leaking slow and steady. I will have to take this steering column out to see what o rings or other such surprises the mad scientist engineers have sent to us mortals.
Old 07-11-2009, 12:39 AM   #6 (permalink)
AchingBack's Avatar
ricky1, is this a tractor that is under warranty? If so, I would not mess with it myself.
__________________
I thank God for these gifts: 2005 Mahindra 2615 HST w/loader, (366 hours), and 3710 backhoe. Markham tooth bar, Bush Hog SQ60 rotary cutter, Bush Hog 3507 angle blade, Bush Hog LLR84 landscape rake w/gauge wheels, Rankin loader mounted forks, Paumco Quick Spade.
SIBKISS - See It Big Keep It Simple Stupid
AchingBack is offline   Reply With Quote
Old 07-12-2009, 07:56 PM   #7 (permalink)
Member
Sorry Ricky, I was thinking of 20 series steering unit cause thats the only ones I've had any problem with leaks. 5500 is different sounds like the input seal is leaking. Good luck with the repair and maybe next time I will put my brain in gear before my fingers.
Dave
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.05412 seconds with 8 queries
