HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-08-2009, 08:55 AM   #21 (permalink)
Elite Member
Default Re: 15 / 16 series block cracks
Quote:
Originally Posted by AchingBack View Post
We are talking about the cracked block on the 3316, owned by jwcinpk. He didn't mention how he discovered the crack. See post #1.
See post #10-11.
__________________
This side of 40
JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
Mahindra 7520/FEL w Skid Steer QC & BH, BX1500 [Mighty Mouse]
IH37 Baler, Hesston Haybine, JD Rake
Bushog, KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, SK Tilt Tach, Grapple. Homemade Splitter/DC Welder
SPYDERLK is online now   Reply With Quote
Old 10-08-2009, 09:06 AM   #22 (permalink)
My crack was substantial and obvious. There was oil gushing from the engine like a lung shot deer.
jwcinpk is offline   Reply With Quote
Old 10-08-2009, 09:09 AM   #23 (permalink)
I'm pretty sure it would be quite obvious when a block is cracked, i.e. fluids leaking all over. One thing that should ease your mind; the 3215 has a loader bracket unlike the 2615. My dealer had a 2615 with a cracked block, come in for repairs. The owner had never even done the 50 hour service, or check anything on the tractor. He just ran it until it broke - total abuse. It cost him $4000 to fix it, and he loves the tractor because he knows he neglected it.
How many hours did they run without servicing?
Old 10-08-2009, 12:23 PM   #24 (permalink)
AchingBack's Avatar
jwcinpk, the guy ran the poor tractor for over 3 years without doing any maintenance.
__________________
I thank God for these gifts: Mahindra 2615 HST w/loader and backhoe. Markham tooth bar, Bush Hog SQ60 rotary cutter, Bush Hog 3507 angle blade, Bush Hog LLR84 landscape rake w/gauge wheels, Rankin loader mounted forks, 2 DR field and brush mowers.
SIBKISS - See It Big Keep It Simple Stupid
AchingBack is offline   Reply With Quote
Old 10-08-2009, 01:48 PM   #25 (permalink)
I had the bolts on my 2615 Loader loosen up before Mahindra did the big Service Notice.
I cleaned the bolts and the holes and used some Red Loctite. 200+ hours later they are still tight. (Knock on wood). Loctite - it does a loader good.
__________________
A government big enough to give you everything you want, is strong enough to take everything you have.
-Gerald Ford
PBinWA is offline   Reply With Quote
Old 10-09-2009, 10:45 AM   #26 (permalink)
Elite Member
The bolts should not loosen if the system is appropriately designed and the bolts are torqued to spec. The full torque is very important to keep the joints stable. Possible problems can arise and remain hidden with Loctite if the bolts are not torqued to spec. The bolts dont back out, but the joints move some and clamping pressure is reduced. I really like the product, but I feel safer seeing a system stay tight without Loctite.
larry
__________________
This side of 40
Old 10-09-2009, 11:00 AM   #27 (permalink)
Quote:
larry
I'm pretty sure the Service Bulletin that came out after I had done it specified using Loctite. I'm not an engineer but have worked with many and from what I can tell Loctite is a very useful tool in situations where vibration is likely to occur.
__________________
-Gerald Ford
Old 10-09-2009, 12:17 PM   #28 (permalink)
I continuosly had trouble with the wheels on my 7010 coming loose. I had a little bit of everything happening from wheels cracking to studs breaking. In the end we added a collar to the wheel and loctite. So far so good.
I agree the subframe should stay tight on it's own, but I think when mine goes back together it will have loctite on it. Loctite isn't a substitute for maintanence checks but I think I'll take a slightly loose bolt over really loose or missing bolts.
Just remember to check them periodically still!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.65729 seconds with 9 queries
