HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-20-2009, 12:37 PM   #1 (permalink)
New Member
Default 2816 and sprayer attachment
I have a 2816 w/FEL. I am looking at sprayer attachments. I want to maintain about 5 acres of grass and control weeks in 4 acres of woods. I have looked at 3pt models with both PTO and electric pumps. My question is there an electrical connector on the 2816 to connect the pump or do i need to add one?
I'm 900 miles from my tractor, so can't run out and look it over very easily. Any info would be great.
Tx..
Bob
boblong51 is offline   Reply With Quote
Old 09-20-2009, 06:53 PM   #2 (permalink)
Sergei's Avatar
Default Re: 2816 and sprayer attachment
Tx..
Bob
One approach would be to get a two piece connector, one end for the tractor side and the other for the sprayer. Use a clip like a battery charger has and connect it to your plus side of the battery and then run a section of wire to the back and then find a spot for the ground wire side. Then connect it when you need it. Also you might check into using coiled power supply cord from the tractor to the sprayer, less change of accidentally ripping the ends off.
__________________
Sergei
Mahindra 2815 HST FEL, KK 5' Rotary Mower ,5' Box Blade
Vinton, Ia
Sergei is offline   Reply With Quote
Old 09-21-2009, 08:59 PM   #3 (permalink)
Any auto electric repair shop should be able to wire it and make sure it is correct, so you don't have any fires or melted wiring harnesses.
__________________
Galen LaWall
Your Mahindra & TYM Tractor Dealer
185 Pearl Street
Batavia, New York 14020
585.343.0770
LAWALLSTRACTOR is offline   Reply With Quote
Old 09-21-2009, 09:00 PM   #4 (permalink)
New Member
Thats a good idea. I was hoping there was already a connector or plug that I hadn't found. My dealer is next to worthless, and even less help.
tx.. Bob
Old 09-23-2009, 12:55 PM   #5 (permalink)
boblong51
Welcome to the forum.
How do you like that 2816?
__________________
Geaux Tigers
________________________
Mahindra 2816 gear w/loader, 5ft Woods Heritage Cutter, 5ft Atlas Angle Blade
duckhunt is offline   Reply With Quote
Old 09-24-2009, 10:47 AM   #6 (permalink)
New Member
I think it is great. I don't get a chance to use it a lot right now, but everything I've done with it has worked out great. I have about 6 acres of grass and 4 of woods that keeps me busy with it when I get a chance to get out there.
I need to look at how to get it ready for winter. This forum is great, and I know I've seen some tips on that already..
Bob
boblong is offline   Reply With Quote
Old 09-24-2009, 10:55 AM   #7 (permalink)
boblong
Good to hear. Did you get your tires filled. If not, its something to look into. Like having a different tractor.
I dont have to much winter prep here in Louisiana. Winter always seems to forget about us.
__________________
Geaux Tigers
Old 09-24-2009, 12:02 PM   #8 (permalink)
kthompson's Avatar
A question not really asked but the electric sprayers to me are great for a lawn or spot spraying but for real use the PTO is much better. If you go that way use quick disconnect to hook hoses to pump so you can remove and flush the pump after use. I found doing so and then dropping the PTO pump into a 5 gallon bucket of oil really helps them last.
__________________
Jeremiah 2:11a "Has a nation changed its gods, Which are not gods?
kthompson is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.19207 seconds with 8 queries
