HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-21-2009, 02:19 PM   #1 (permalink)
New Member
Default 104 LOADER QUESTIONS, SEEMS WEAK ??
Hi and hello , first post here and long time lurker. I was a tractor owner wanna-be for a while there until I finally pulled the trigger on a 2015HST. My question has to do with the loader capacities. I understand the loader should be able to handle 900 some odd pounds. Well this weekend I bought some railroad ties to build a retaining wall. I was really surprized that the loader would not lift 4 ties. It would only hand 3 at a time ?? Is there an adjustment some where on the hydraulic system or weak pump ??? I figure at 200lbs a tie it was only lifting about 600 lbs. seems kinda weak---or not ?
expressfish is offline   Reply With Quote
Old 09-21-2009, 02:56 PM   #2 (permalink)
J_J
Super Member
J_J's Avatar
Default Re: 104 LOADER QUESTIONS, SEEMS WEAK ??
It would depend on how close into the bucket the ties were. I believe loader lift capacity is at the bucket attachments points, and then you subtract the bucket weight. So if they advertise 900 lbs, and the bucket weighs 150 lbs, then your lifting capacity capacity becomes 750 lbs.
__________________
J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done, if-fen you want to..
J_J is offline   Reply With Quote
Old 09-21-2009, 03:07 PM   #3 (permalink)
New Member
Im sorry, I should have mentioned this was with the forklift attachment. I slid the ties out of the bed of my truck onto the forks and pushed them all the way back so the load wouldn't be at the tip of the forks.
Old 09-21-2009, 03:12 PM   #4 (permalink)
J_J
Super Member
J_J's Avatar
Samething, subtract the weight of the forks. You could lay one of them on a bathroom scale and check the weight.
__________________
J.J.
Old 09-21-2009, 03:13 PM   #5 (permalink)
LD1
Gold Member
LD1's Avatar
How were you carrying the ties???
Most manufactures advertise the lift capacity @the pivot pins, as JJ mentioned. But seldom does anyone lift anything at the pins.
Most loaders loose about 25% by the time you get to the bucket edge.
You can lift 915 lbs @ the pins. 915-25%= only about 686lbs at the bucket edge. The further forward you go (like adding clamp on forks) the less you can lift.
__________________
".........there is only one way to find out."
"Ok, hold my beer and watch this.........."
Kubota L3400GST W/LA463 FEL
JD 261 3PH mower
3 Homemade wood hauling trailers
Dolmar 7900
Husqvarna 266se
LD1 is offline   Reply With Quote
Old 09-21-2009, 03:19 PM   #6 (permalink)
New Member
so I guess thats about right, 600lbs of railroad ties and 150lbs of forks pretty much sums it up. It still beats the **** out of manual labor ! If I may add, attached is pic with some sort of hydraulic box. In the lower center there is a kinda selector lever that has two positions. A bolt holds it in place, what are the two positions for ??
Old 09-21-2009, 03:24 PM   #7 (permalink)
That selector is used to change the hydraulic flow route. One position is without a loader and the other is with a loader.
__________________
Galen LaWall
Your Mahindra & TYM Tractor Dealer
185 Pearl Street
Batavia, New York 14020
585.343.0770
LAWALLSTRACTOR is offline   Reply With Quote
Old 09-21-2009, 03:58 PM   #8 (permalink)
New Member
thanks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.17135 seconds with 9 queries
