HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-25-2009, 03:28 AM   #1 (permalink)
New Member
Default 3215 HST
Is it an indication that the hydraulic fluid and filter(s) need changing when the tractor seems to lose strength in the backhoe/FEL plus its hill climbing ability is weakening as well? The tractor was bought new in october '07 and has about 76 hrs. and no hydraulic attention at all. My theory is that since it was new, that break-in crud is blocking the flow thru the filter causing the loss in hydraulic power. Is that thinking correct?
Boit is offline   Reply With Quote
Old 09-25-2009, 03:48 AM   #2 (permalink)
Default Re: 3215 HST
Quote:
The first filter change is at 50 hrs. Check you owner manual maintinance schedule.
__________________
Galen LaWall
Your Mahindra & TYM Tractor Dealer
185 Pearl Street
Batavia, New York 14020
585.343.0770
LAWALLSTRACTOR is offline   Reply With Quote
Old 09-25-2009, 03:56 AM   #3 (permalink)
New Member
Dang! How did I miss that!? I'll change the fluid AND the filters ASAP! Thanks. BTW, is the problem I described a classic example of the fix you offered? I feel like an idiot!
Old 09-25-2009, 09:35 AM   #4 (permalink)
I wouldn't guarantee that changing the fluid & filters is going to solve your problem, but I would start there.
__________________
Galen LaWall
185 Pearl Street
585.343.0770
Old 09-25-2009, 11:32 AM   #5 (permalink)
Approved Advertiser
wallace's Avatar
One other thing I would check quickly is...Make sure you don't have the 3 point hitch lower links binding up against the backhoe if you have the links on and raise them up they will hit the bottom of the backhoe creating a dead heading pressure which will make the tractor feel sluggish.
__________________
Wallace Tractor and Equipment
www.wallacetractorandequipment.com
RICK WALLACE
(570) 689-7494
I only need 2.10 million in bailout!
wallace is offline   Reply With Quote
Old 09-25-2009, 05:58 PM   #6 (permalink)
Good thing Rick thought of that, as it is a very good possibility. I usually recommend when using the backhoe, take the 3PH arms off, because lifting them up against the backhoe is so easy to do without knowing.
__________________
Galen LaWall
185 Pearl Street
585.343.0770
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.15653 seconds with 8 queries
