Re: 4110 battery gave out this week Quote:
Originally Posted by coffeeman Should I replace at end of season or......should I wait till spring?
I figure I'll run the tractor about 5 times till I put away for year. A quick jump of the battery gives me enough juice for the day.
I'm thinking of replacing and losing 5 months warrenty. Wondering what you all think?
Cheers....coffeeman | If it will charge at all, and discharges over time try a cheap trickle charger to keep the battery with enough juice in it to start it until you buy a new battery in the spring.
I've also banged on the bottom of the battery with a rubber or wooden mallet to get some more time out of them. Sometimes this breaks loose the stuff that settles in the bottom and keeps the cells from charging.
__________________ Mahindra 4110 w/ FEL, Dearborn 10-152 12" plow, Ford LIFT E Disk, 1 row cultivator, PHD, 6' Box Blade |
