Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-08-2009, 08:26 AM   #1 (permalink)
New Member
Default 2615 HYDRAULIC PROPBLEM
Looking for some help please . This problem was self inflicted I have been very happy with my 2615 (just wish I had went bigger).
I was doing some clearing in my woods last sunday when I guess I hit a log on the undercarrrige , It contacted my hydraulic filter and snapped it off .
I had to replace my filter carrige ,so I had to remove the pipes from the side of the transmission to get the filter carrige off ,that caused me to loose all my fluid. I replaced the filter carrige and filter filled back up with fluids . Now it seems that I have air in the system at low idle the loader works fine but at fast idle its jerky . I have tried to bleed the system with know good results .Also i have noticed at short run times the fluid looks white in color suggesting further that I have air . Any help would be great thanks in advance.
Dan.s
BUG322 is offline   Reply With Quote
Old 10-08-2009, 09:50 AM   #2 (permalink)
driver444's Avatar
Default Re: 2615 HYDRAULIC PROPBLEM
The hydraulic system bleeds itself. You're doing the right thing. Just keep working the loader up and down, curl the bucket back and forth, and run the 3 point up and down. Repeat this until the problem stops. Check the fluid level. Eventually the air will get out.
PS. When you lose ALL of your fluid, that's probably close to 5 or 5 1/2 gallons on that machine. Is that what you put back in?? Losing all your fluid is really no diffierent than draining it all out to change it.
driver444 is offline   Reply With Quote
Old 10-08-2009, 10:02 AM   #3 (permalink)
New Member
DRIVER 44
YES I PUT 23 QTS BACK IN THE UNIT AND ITS SHOWING FULL NOW ,WILL AIR MAKE THE PUMP NOISY UNTILL IT CLEARS? I ONLY NOTICE THIS AT FAST IDLE WHILE MOVING THE LOADER..
THANKS FOR YOUR HELP.
DAN.S
Old 10-08-2009, 11:23 AM   #4 (permalink)
driver444's Avatar
Yes, if the pump is running dry it will make more noise. I'm not sure how that could be though, if the loader and 3 point are moving up and down, and the transmission is full.
Does your power steering work OK?
I think I would pull the line off the pump and fill it with oil. Maybe the system lost its prime.
How long was the tractor running after you realized the fluid was gone?
Old 10-08-2009, 11:51 AM   #5 (permalink)
New Member
Driver 44
It only ran for just a second ,before i shut it off and fixed it in the field . my power steering works great . and the loader as of now seems to have plenty of power i can lower it all the way down and pick up the front of the tractor but i still get that jerky motion up and on the way down . I will try what you have told me tonight ,and see if it gets any better I was just scared to really run it with it having some problems ..
sure appreciate your time
Dan .S
Old 10-08-2009, 04:54 PM   #6 (permalink)
driver444's Avatar
Don't bother messing with that pump.
If your steering is fine, and you can lift the tractor with the bucket, there's nothing wrong with the system. If your pump was dry, that wouldn't happen. Any air you have in there will work it's way out as you use it. I wouldn't worry about a thing.
Once in a while on my 2015, I'll raise the bucket at high idle, and it will have a "jerk" in the movement also. Nothing to worry about.
I know how you feel though. It's a condition called "paranoia."
Old 10-08-2009, 07:44 PM   #7 (permalink)
It sounds to me like you may have an air leak on the suction side of the system. This could be very possible considering what happened to the tractor. Check all of your joints and lines in the area where the damage was.
__________________
Galen LaWall
185 Pearl Street
Batavia, New York 14020
585.343.0770
LAWALLSTRACTOR is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.05483 seconds with 8 queries
