HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Mahindra > Mahindra Owning/Operating
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-18-2009, 01:43 AM   #1 (permalink)
bindian's Avatar
Default "Spare Parts"
I found a set screw on my forward magnetic plug when I was changing transmission fluid. I am thinking this was dropped during installation and another one installed. The service manager where I bought the 6520 (he has opened his own shop now) thinks it goes on a shifter indent. He said he wasn't surprised. So I guess this kind of thing has happened before. Since I don't have any shifting problems, I think this is an "extra" setscrew. I sure hope it is. My hour meter is at 497.5 hours. Also, my rear axle fluid is suppose to be separate from transmission fluid. I suppose to have a drain plug on each side and add fluid after removing the left and right axle breathers. The problem is ...........there are no plugs where the ops manual photo shows them. I also seem to be missing the second from the front plug also, which is not a bad thing, except no magnet. It is like these three plugs were never drilled and tapped. The flat spot is there for them, but just flat surface. So now I will have suck the fluid out to change it. The ex service manager also said to drop a magnet in to see if any metal is there. The problem with that is there is 3 inch diameter or so axle blocking the magnet's access. I will present this all to Tomball and my dealer on Monday.
hugs, Brandi
spare-parts-10-17-09-setscrew-transmission  spare-parts-10-17-09-setscrew-transmission
bindian is offline   Reply With Quote
Old 10-28-2009, 01:12 PM   #2 (permalink)
bindian's Avatar
Default Re: "Spare Parts"
I told Top Flight about my extra set screw this morning. They documented it in the computer and gave me a print out on it. Now if something goes wrong and the shifter is to blame, I will have something to fall back on.
hugs, Brandi
Old 10-28-2009, 11:42 PM   #3 (permalink)
Elite Member
sandman2234's Avatar
Extra parts are never good when you find them in the bottom of an oil pan. Even if the screw was replaced by the mechanic, he should have never sent the machine out until that screw was found. Problem with that is nowadays, good help is hard to find, and a good dealer knows it. Hopefully it doesn't end up being a problem!
David from jax
__________________
A serious accident is one that money won't fix.
sandman2234 is online now   Reply With Quote
Old 10-29-2009, 03:12 AM   #4 (permalink)
bindian's Avatar
Quote:
David from jax
My dealer's mechanic says he sees this a lot because the guys that assemble the machines know the magnetic plugs will catch them if dropped. Being a mechanic, I am really not concerned with finding an unused setscrew on a magnetic plug. Now if it was accompanied with metal shavings and the setscrew looked like it went through a meat grinder...........then I would be really
hugs, Brandi
Old 10-29-2009, 10:20 AM   #5 (permalink)
Elite Member
Brandi, what did the dealer say about the other drain plugs the manual shows and you don't have? That seems way strange to me.
MarkV
MarkV is offline   Reply With Quote
Old 10-29-2009, 12:14 PM   #6 (permalink)
bindian's Avatar
Quote:
MarkV
After I take photos this weekend, I will show them and fire the photos off to Tomball along with the photo from the manual.
hugs, Brandi
Old 11-03-2009, 08:56 PM   #7 (permalink)
bindian's Avatar
MarkV
I realized the operator's manual that I have was given to me when I ordered the tractor. It was an extra in the office, so I think the manual I have is for an earlier model 6520. The manual has a reference to June 05, so I guess it is two years older than my 6520. I will take photos and ask Tomball about it.
hugs, Brandi
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.27432 seconds with 9 queries
