I have a Mahindra 3215 with around 250 hours on it. I was working it at my moms place, using the loader, I had just pushed out some saplings and underbrush when I moved to park and hand load some debris. It just died as if I shut it off. It restarted like normal, but died after 2-3- seconds. I checked for any fluid leaks, none found all seemed ok and fluid levels ok. When I tried it again I did notice my glow plug light didn't come on but, my PTO light did come, although not engaged and engine would start. That just confused me more. I checked fuses and all where ok except the instrument panel fuse (10 amp). Replaced fuse with 10 amp and it blew. The instrument panel then looked normal before fuse would blow. Although if fuse was blown or not the engine would still die. While running no smoke no rough running, no missing. Engine would perfect, just only 2-3 seconds. Just as if you started it and turn it off right away. As far as the fuse I tried a 15 amp and it worked, then replaced with brand new 10 amp and it hasn't blown after 10-15 tries while I was testing everything I could think of. Individually I disconnected temp and oil sensors, no effect that I could tell. Could not find any chaffed wires or breaks, all seem very well protected. I can't find anything in owers manual to help and I haven't gotten a repair manual for it yet. Electric fuel pump works. There are two wires that run to back of injector pump, one is hot while switch is in run position, and other is hot only in start position. At the moment just using test light, I dont have any specs for testing otherwise. Does anybody have any idea as to whats going on? And please no wisecracks, this is discouraging when combined with other things that are going on around here.
Thanks
Timmanny
Thanks
Timmanny
