Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Jan 2010
    Posts
    4
    Default 6000 Clutch problems
    Just was wondering how many people have had to replace their clutch on the Mahindra's. I have a 2002 6000 FWD, with only 189 hours.
    My clutch went out and dealer is saying around 1500-2000 to fix. Anyone know if this is in the ballpark.
    Don't think I ride the clutch so a bit concerned that its out.
    Could being out of adjustment (not having 1 inch of play) be the issue?
    thanks for any feedback
    mike
  2. #2
    Super Star Member brin's Avatar
    Join Date
    Jul 2009
    Posts
    10,866
    Georgia - Mt. Vernon by The Store just 5 miles east and right by the big oak tree then to the creek.
    Default Re: 6000 Clutch problems
    Quote Originally Posted by mikewd2 View Post
    mike
    Are you sure your clutch is not just stuck ( rusted ) as opposed to needing replacement. If you are just not able to shift into a gear there are solutions to that .. try using the search feature at the top of the page and type in " stuck clutch " and you will find a lot of information. You might also want to post what your clutch is doing to enable others to give you better advice. What are the symptoms. ?
    Bob
    WORRYING does not take away tomorrow's TROUBLES, it takes away today's PEACE.
    NH - TC-29 , FEL, Bush hog, Bush hog brand finishing mower, Post hole digger, 6' Back blade, sub-soiler, Pallet forks, 20KW PTO Generator , 21 hp Murray Mower
    JD -3020 with FEL and a 16 HP. K-Grow Lawn Tractor (bought from K Mart 1994) and runs great !
    Clark 130 EN Mig Welder
  3. #3
    Join Date
    Aug 2003
    Posts
    1,137
    Welfare Capital of the World...KY
    2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
    Mine made it 900 hours. I am told the replacement is a better clutch. I think I paid $1200 parts and labor to have mine replaced.
  4. #4
    New Member
    Join Date
    Jan 2010
    Posts
    4
    Sorry for not stating what the tractor is doing.
    When I put it it gear forward or reverse it has no power, appears the clutch is slipping. It will go, but very very slow - better in L gear, won't climb even the slightest incline.
    mike
  5. #5
    Join Date
    Jul 2003
    Posts
    1,912
    Central VA, USA
    Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
    Did you try to adjust the clutch out??? And yes, just leaving you foot against the clutch pedal will put leverage against the clutch plate/flywheel. Barring adjustment (pls attempt to do so before going on...)to bring it into spec, if your dealer says $2000 to replace, you have a choice, get it fixed or do without the tractor. Sorry, but there it is. BobG in VA who also has a 2002 6000 FWD.
  6. #6
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,169
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    mike
    The clutch pedal should have play - absolutely. If it does not it is the same as if youre resting your foot on it. Top play decreases as a clutch wears unless there is corresponding wear [rare] in the lift mechanism/throw out bearing. An inch is nominal, but a little less is ok. If there is none you should adjust it immediately. It may not be worn out or even burnt, but you can be sure its life has been shortened.
    larry
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, CCM165 Drum Mower, JD Rake
    JD 127 bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
Similar Threads
  1. Clutch problems YM 1500
    By jeffscoggins in forum Yanmar
    Last Post: 01-19-2009, 09:43 PM
  2. FarmTrac DTC 360 Clutch Problems - Follow Up
    By Qapla in forum Parts/Repairs
    Last Post: 11-27-2008, 06:15 PM
  3. 2030 new clutch problems
    By psj12 in forum John Deere Owning/Operating
    Last Post: 10-28-2007, 11:51 AM
  4. Tires Clutch problems / tire pressure
    By ekodish in forum Iseki
    Last Post: 10-04-2004, 05:03 PM
  5. YM2001 Clutch Gone (Help)
    By Bittersweet in forum Yanmar
    Last Post: 08-15-2004, 02:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
