Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Apr 2007
    Posts
    15
    South Lyon Mi
    Mahindra 2615
    Default 2615 Hydraulic filter/fluid
    I have a 2615 (gear) tractor. I recently replaced the hydraulic fluid and filter for the first time. I used a wix 51663 filter and traveler universal hyd fluid from TSC
    Traveller Universal Tractor Trans/Hydraulic Fluid, 5 gal. - 0806391 | Tractor Supply Company
    It may be in my head but it almost seems like I am getting a hyd pump cavitation at higher RPM's now? The Wix filter is about 1/3 again shorter than the stock filter and I am not 100% convinced that the fluid is correct, though the dealer I bought it from recommended any 32 hydraulic fluid?
    Can anyone enlighten me on my situation?
    Thanks!
    Thanks!
    Dave at www.dryseats.com
  2. #2
    Elite Member
    Join Date
    Sep 2002
    Posts
    2,682
    Red Bluff, CA
    Changes often!
    Default Re: 2615 Hydraulic filter/fluid
    Quote Originally Posted by dtsdryseats View Post
    Thanks!
    You probably are cavitating the pump, and that is real hard on pump life. I'd use the factory filter. I'm not familiar with the specs on the TSC hy-trans, we recommend the factory branded Mahindra Hy-Trans, or Chevron THF-1000 or Mobil 424.
    Dave
    Red Bluff, California
Similar Threads
  1. Backhoe JD 110 Tractor Loader Backhoe
    By bushytlb in forum John Deere Owning/Operating
    Last Post: 05-09-2011, 06:09 PM
  2. RO Hydraulic oil
    By juiceman39 in forum Hydraulics
    Last Post: 07-20-2009, 12:31 AM
  3. 2615 hydraulic line issue
    By Nickthegrip in forum Mahindra Owning/Operating
    Last Post: 04-21-2009, 10:20 AM
  4. Old Backhoe loosing hydraulic power
    By JohnBarlow in forum Hydraulics
    Last Post: 08-21-2005, 10:15 PM
  5. Hydraulic hiss on new JD2210 (normal?)
    By grimmt in forum John Deere Owning/Operating
    Last Post: 10-12-2004, 03:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
