Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Gold Member AGGIE00's Avatar
    Join Date
    May 2010
    Posts
    473
    Default Re: how to bleed fuel lines
    I agree with everything said here except loosening all the injector lines. It only takes one.
    MY2012 John Deere 5083e-563 FEL, 2008 CAT 272C with 60" Bradco Mulching Head
  2. #12
    Join Date
    May 2002
    Posts
    740
    Close to Petersburg
    Mahindra 2516
    That is the way I was shown so I've always done it this way. Next time (hopefully there is no next time) I'll just try with one
    Thanks for the help though!
    Quote Originally Posted by AGGIE00 View Post
  3. #13
    Silver Member genusCastor's Avatar
    Join Date
    Oct 2008
    Posts
    142
    East Texas prairie
    Mahindra 3510 w/FEL
    I should mention that I tried cracking open an injector, but no fuel ever came out. I cranked it 3 or 4 times (15 sec at a time, with several minute breaks to let the starter rest a little).
    The cock valve on the injector pump is awesome. Tractor started on the first try (cranked 10 sec or so), and I never even got any fuel on my hands.
    Or that would be a for the grease monkeys.
    - djb
    The best things in life aren't things.
    2003 Mahindra 3510 with front end loader
    2010 Dixie Chopper 2550 ZTM: 25 hp Kohler, 50" cut
    2008 Kubota RTV900
  4. #14
    Platinum Member jpm1's Avatar
    Join Date
    Feb 2008
    Posts
    590
    Panther Lake, Oswego County New York
    Mahindra 2810 HST, Kioti DK35SE HST
    Ya know this is all new to me. I have a 2810, and have run it dry several times the first week i took delivery. The only thing i did was put fuel in the filter , tighten it up, get on and turn the key. A couple of seconds later it started and i was in business again. This is the easiest tractor i have ever started in this situation. Love my Mahindra! . . .John
    Attached Thumbnails Attached Thumbnails how to bleed fuel lines-036-jpg   how to bleed fuel lines-050-jpg
    Lord, Help me to be the man my dog thinks i am . . .John. Mahindra 2810HST, 108H loader with Quick tach buckets and forks. Kioti DK35SE HST with loader, Hyd. top link and second set of rear remotes, 60" and 66" buckets, Kubota 900 RTV and a bunch of other good stuff
    Buy more equipment, It makes life easier.!
  5. #15
    Join Date
    Sep 2005
    Posts
    1,746
    Batavia, NY
    Mahindra -------------
    The recomended proceedure really is easier then that.
    Galen LaWall
    Your Mahindra Tractor Dealer
    185 Pearl Street
    Batavia, New York 14020
    585.343.0770
  6. #16
    New Member
    Join Date
    Jan 2013
    Posts
    1
    shediac river new brunswick ca
    kubota 1860
    On my1860, changed both fuel filters..i have a small air bubble in the top filter...will this cause a problem...engine starts, a little rough at first but then seems to run smother ....Thanks for your help
  7. #17
    Silver Member SHORT KID's Avatar
    Join Date
    Feb 2010
    Posts
    180
    Poconos, PA
    Mahindra 2615 hst fel, bh
    I always start my tractor and let it warm up before changing the fuel filter. If I have a loss of power when using it, I just shut it down as soon as I can get it back to the shop. I only have one small filter with the plastic site glass and two bleed screws and shut off valve. I shut the fuel off loosen the glass and drop the filter, catching any spillage. After cleaning the glass and filter area I install new filter but I DO NOT tighten the filter. When it is almost tight I turn the fuel on and watch that the glass fills. When full I tighten the glass and start engine at a high idle and run until the air if any is out. I never used the screws on the filter to bleed, or cracked the injector lines. If I was going to crack the injector lines, it would be the furtherest from the pump. After 3 diesel tractors and 4 diesel trucks I think I have it down now!!!!
Similar Threads
  1. ethanol and fuel lines
    By Soundguy in forum Oil, Fuel & Lubricants
    Last Post: 05-31-2010, 09:41 PM
  2. Oil & Fuel Fuel problems (algae)
    By rxk9394 in forum Kubota Owning/Operating
    Last Post: 01-08-2010, 05:36 PM
  3. Oil & Fuel BX24 might want to check the fuel lines.....
    By fred98050 in forum Kubota Owning/Operating
    Last Post: 02-06-2009, 01:14 PM
  4. Motor oil and other fuel additives
    By nosliw in forum Oil, Fuel & Lubricants
    Last Post: 02-17-2007, 01:12 AM
  5. Oil & Fuel Which fuel should I use
    By DDT in forum Owning/Operating
    Last Post: 02-02-2003, 09:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
