Results 11 to 20 of 21
10-20-2012, 09:44 AM #11Member
- Join Date
- Oct 2009
- Posts
- 37
- Location
- Lower Alabama
- Tractor
- 2006 2615 4WD Mahindra
12-16-2012, 09:46 PM #12Silver Member
- Join Date
- Feb 2008
- Posts
- 243
- Location
- Central Maine
- Tractor
- Mahindra
Well here we go AGAIN! Its 15degrees out, its a snow storm, tractor has worked fine all year, go to start it,.....NOTHING!
Troubleshoot it. Failed ignition switch AGAIN!
Just got home from town, had to go find an ignition switch on a Sunday night. Not a happy camper!"Contentment is not the fulfillment of what you want but the realization of how much you already have"
"The best things in life,...aren't things"
12-16-2012, 09:50 PM #13Silver Member
- Join Date
- Feb 2008
- Posts
- 243
- Location
- Central Maine
- Tractor
- Mahindra
12-16-2012, 09:52 PM #14Silver Member
- Join Date
- Feb 2008
- Posts
- 243
- Location
- Central Maine
- Tractor
- Mahindra
By the way I only have about 50 hours on the last OEM ignition switch. DO NOT BUY A MAHINDRA/CUB CADET IGNITION SWITCH FOR YOUR TRACTOR!
12-17-2012, 10:34 PM #15Elite Member
- Join Date
- Sep 2002
- Posts
- 2,644
- Location
- Red Bluff, CA
- Tractor
- Changes often!
Re: Ignition switch is junk on my 2615
Wyld Bill, can you figure out why they are failing? Like I have said before, we have sold literally hundreds of the 2615/2816 and the 2015/2216 and they all take that switch. I have sold maybe one or two switches. I carry one in stock, and it is covered in dust. So I believe you entirely, but we have something contributing to the failure I'd guess. Not a bad idea to use a universal switch.
Dave
Red Bluff, California
12-19-2012, 09:56 PM #16Silver Member
- Join Date
- Feb 2008
- Posts
- 243
- Location
- Central Maine
- Tractor
- Mahindra
Yeah I sure do. I dissected the first one that failed. I have pictures of it somewhere. Basically there is a plastic shaft that run down through the center of the switch. Copper plates or copper plated metal plates have a hole in the center of them for the plastic shaft to go though. From vibrations and what not the plates wear into the plastic shaft creating a groove. Then instead of the plates making good contact they are stuck in the grove and you have no ignition power.
12-20-2012, 11:21 AM #17Elite Member
- Join Date
- Sep 2002
- Posts
- 2,644
- Location
- Red Bluff, CA
- Tractor
- Changes often!
I appreciate the good description. That would sound like a switch with a bazillion starts or a very old switch, which obviously isn't the case on your rig. Do you have extra lights wired into the system or anything of that nature that could be putting an extra load on the switch which might heat things up inside the switch and cause the plastic post to get soft or something? I'm just curious since we see this so rarely and have sold so many of them. We do not have much cold weather, but even so I can't see where that relates to what you saw in the first failure. If you take the second switch apart, let us know what you find, if you haven't already tossed it. Thanks!
Dave
12-20-2012, 12:44 PM #18Silver Member
Approved Advertiser
- Join Date
- Nov 2002
- Posts
- 267
- Location
- Bethany, CT
- Tractor
- Mahindra's
I have to say I have had the same experience as Dave. We dont see switch problems with these ignition switches. The "15" series tractors were our biggest selling tractor models at the time and have yet to replace a switch on one yet. My personal 3015 sits outside in the elements and no problems to this day, knock on wood!
MAHINDRA PARTS ONLINE
12-20-2012, 01:03 PM #19Elite Member
- Join Date
- Sep 2002
- Posts
- 2,644
- Location
- Red Bluff, CA
- Tractor
- Changes often!
Wyld Bill, since you are blowing snow, do you have a hydraulic or electric chute rotator? If electric, is it totally isolated from the switch somehow? Are you using relays? Something out of the ordinary is happening here, even if we aren't smart enough to figure it out. Meanwhile, use cheap switches and carry a spare.
Dave
12-20-2012, 01:08 PM #20Elite Member
- Join Date
- Sep 2002
- Posts
- 2,644
- Location
- Red Bluff, CA
- Tractor
- Changes often!
Wyld, I just did a little search and found this:
So here's the set up I'm running.
2006(?) Mahindra 2615 HST.
1" wheel spacers for 2-link tire chains
Loaded rear tires
Kats engine coolant heater
Origonal Cab Co. soft cab kit
6 Halogen flood lights
70" Provonost snowblower with electric chute rotator & adj. skids added.
Dome light, heater, & cup holder in the cab
So we have 6 extra lights, electric chute rotator, heater, etc. Obviously you are a sharp guy, but I just think that somehow the extra electrical loads are causing the switch to be used beyond it's designed duty cycle? Not sure, just guessing. BTW, sounds like a nice setup!Dave
Similar Threads
White Field Boss 31 (Iseki) ignition switch
By knealeski in forum Parts/RepairsReplies: 9Last Post: 05-31-2012, 11:44 PM -
Jinma 284 ignition switch
By meporsche in forum Chinese TractorsReplies: 3Last Post: 09-20-2010, 10:11 PM -
IH 300u ignition switch wiring question
By ih300u in forum General Vintage TractorsReplies: 3Last Post: 01-31-2010, 12:33 AM -
Ignition Switch Removal B6200 Kubota
By flowerlvr98 in forum Parts/RepairsReplies: 1Last Post: 11-20-2009, 10:09 PM -
JM 284 LE IGNITION SWITCH REPLACEMENT
By corey in forum Chinese TractorsReplies: 1Last Post: 08-28-2006, 04:06 PM
