Results 1 to 10 of 17
05-25-2011, 09:12 PM #1New Member
- Join Date
- May 2011
- Posts
- 10
- Tractor
- mahindra 2615 ml 106
Mahindra starter wiring [helP]!!
ok long story short starter has 5 wires going to it i know the main 3 but i dunno where the other 2 go.
long story;
so my dad is 60 and he wanted a tractor so he went and bought a mahindra2615 hst. he lets it sit for months at a time, and has to jump it off a lot. the last time it wouldnt start up, "im and automotive mechanic" i told him to go buy a battery and change it out, the original was 5years old been dead atleast 6 times, time for a new battery. so ignores me, pulls the starter off the tractor and has it tested, they tell him to go buy a new battery too. so he gets the battery now and doesnt know how to re wire the starter so he calls me, any car has 3 wires coming off the starter solenoid
one to the starter motor
one from the battery
one from the inition switch via starter relay
what are the other 2 for he said they were connected but doesnt remember witch terminals they were on.
05-25-2011, 09:17 PM #2New Member
- Join Date
- May 2011
- Posts
- 10
- Tractor
Re: Mahindra starter wiring [helP]!!
if someone could just take a picture of there starter solenoid that would be awesome. our mahindra dealer shut down so theres none i can go look at thanks guys.
05-25-2011, 09:50 PM #3
I have a freind with a 2615, I'l try to get a pic tomorrow.
05-25-2011, 10:08 PM #4New Member
- Join Date
- May 2011
- Posts
- 10
- Tractor
sweet thanks.
05-25-2011, 10:38 PM #5Bronze Member
- Join Date
- May 2011
- Posts
- 54
- Location
- upsate ny
- Tractor
- 2011 Mahindra 3016HST, 1991 Bolens GT2000
Sorry just went out and looked but my 3016 only has 3 wires. Going to go out on a limb though and say you have your activation wire, starter wire, and power wire. Those three should be easy enough to identify and unless you have a ground wire from the block the other two should go to battery terminal. Because I can't think of why you would want power only when your starter is engaged.
05-25-2011, 11:36 PM #6New Member
- Join Date
- May 2011
- Posts
- 10
- Tractor
thats what i was thinking too. i know one of them goes to the power terminal, i looked again and it powers the ignition, the other turns on a solenoid on the other side of the block (connected to the injector block) when its connected to power so im just not sure about that one. i just dont wanna burn anything up.
05-26-2011, 05:28 PM #7
Sorry, but I don't see 5 wires.
05-26-2011, 05:36 PM #8New Member
- Join Date
- May 2011
- Posts
- 10
- Tractor
Ok thanks anyway.
05-26-2011, 09:40 PM #9
My 2615 doesn't have 5 wires either.
I thank God for these gifts: 2005 Mahindra 2615 HST w/loader, (485 hours), and 3710 backhoe. Markham tooth bar, Bush Hog SQ60 rotary cutter, Bush Hog 3507 angle blade, Bush Hog LLR84 landscape rake w/gauge wheels, Rankin loader mounted forks, Paumco Quick Spade, Agri-Ease 3 point log splitter.
05-27-2011, 02:11 PM #10Platinum Member
- Join Date
- Feb 2005
- Posts
- 786
- Location
- Eastern Iowa
- Tractor
- Kubota B7610HSD, Mahindra 6500 4WD, JD 440ic crawler, ih300utility with loader, jacobsen mower with kubota 3cyl engine, 1066 farmall, 2 560 farmalls.
If you go to mahindras website you can plug in the serial number and get manuals, wiring diagrams etc. Mahindra Tractor - Compact tractors, utility tractors, farm tractors, ag tractors, attachments, implements & farm equipment - all built tough! 24/7...
here is the direct link MAHINDRA USA TRACTORS 24/7 OWNER'S CARE
hthKubota B7610HSD, RCK60-24B MMM, LA352 Loader, Maschio 50" tiller
Mahindra 6500 4WD ML265 Loader, 72" Bucket & Toothbar, Root Grapple, Pallet Forks, Spear
511 Backhoe, Bushhog 296 Rotary Mower, Woods 700 blade, Jinma 6" Chipper, 3pt Spreader
440IC John Deere Crawler
-Tim
Similar Threads
Z400 starter wiring
By iternawheel in forum Kubota Owning/OperatingReplies: 0Last Post: 03-09-2011, 12:45 PM -
Mahindra vrs JD
By shamban in forum Mahindra Owning/OperatingReplies: 91Last Post: 08-25-2010, 06:23 PM -
R2500 Starter
By leekal in forum Mitsubishi/SatohReplies: 11Last Post: 04-25-2010, 06:41 PM -
JD 317 Broken Starter???
By Bill E in forum John Deere Lawn & GardenReplies: 4Last Post: 01-30-2010, 04:09 AM -
MAHINDRA QUESTIONS
By Travis_R in forum Mahindra Owning/OperatingReplies: 18Last Post: 07-28-2004, 10:29 PM
