Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Silver Member mlitt12345's Avatar
    Join Date
    Oct 2005
    Posts
    102
    Newton, Alabama
    2005 Mahindra 4110
    Default 4110 with a front mounted winch
    I installed a 8000lb single line pull champion winch from tractor supply to my 4110, had to fabricate a mount for it. Welded some 3/8" flat stock to the top of the front loader crossover support and the frame itself, giving me more strength and metal to mount the winch to. here are a few pics. Thanks, Mike
    Attached Thumbnails Attached Thumbnails 4110 with a front mounted winch-imag0216-jpg   4110 with a front mounted winch-imag0219-jpg   4110 with a front mounted winch-imag0220-jpg   4110 with a front mounted winch-imag0223-jpg
  2. #2
    Elite Member AchingBack's Avatar
    Join Date
    Jun 2005
    Posts
    3,518
    Southern Oregon
    Mahindra 2615HST
    Default Re: 4110 with a front mounted winch
    Quote Originally Posted by mlitt12345 View Post
    What are you going to do with the winch?
    I thank God for these gifts: 2005 Mahindra 2615 HST w/loader, (875 hours), and 3710 backhoe. Markham tooth bar, Bush Hog SQ60 rotary cutter, Bush Hog 3507 angle blade, Bush Hog LLR84 landscape rake w/gauge wheels, Rankin loader mounted forks, Paumco Quick Spade, Agri-Ease 3 point log splitter. Pine straw rake.
  3. #3
    Join Date
    Oct 2005
    Posts
    102
    Newton, Alabama
    2005 Mahindra 4110
    I have hunting lease that I use my tractor to do food plots, bush hogging etc and it has a few wet spots on it that even with 4wd you can get into trouble, I have been stuck a few times. Will be nice to have the ability to winch if necessary. Also can use it to winch logs, move around our heavy shooting houses etc. The only big concern I have with a winch this size is the amp draw so I will have to use a duty cycle to keep from zapping the battery. Thanks, Mike
  4. #4
    Super Member bindian's Avatar
    Join Date
    Feb 2007
    Posts
    6,972
    Willis, Texas
    Mahindra 6520 4WD
    What about that hot amp using motor blocking airflow to the radiator. Have you read here about known 4110 hot running problems?
    But overall it looks like a neat installation.
    hugs, Brandi
  5. #5
    Elite Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    3,252
    texas
    Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
    Looks cool!!
  6. #6
    Join Date
    Oct 2005
    Posts
    102
    Newton, Alabama
    2005 Mahindra 4110
    Never have had running hot issues with mine. There is plenty of air flow to the radiator there are side grills also and the front ones are not blocked either, the winch sits about 10 inches in front of the grill-hood. Thanks, Mike
  7. #7
    Join Date
    Apr 2005
    Posts
    844
    Erin, Tenn.
    2001 Mahindra 4110
    I always had heat problems with mine the past 9 years when cutting grass when dry & hot and then about 2 months ago I did the battery box modification to drop the battery down from in front of my radiator. I've cut twice now in this terrible heat we're having this summer and I haven't had a bit of problem with overheating. I can cut my full 5 1/2 acres without having to blow the radiator out until I'm done. Before the mod I would have to stop about once an hour or so to blow the chaff out of the radiator from the engine side in order to keep going. I don't think anything on the outside of the sheetmetal would affect the cooling at all on the 4110.
    That winch mount looks nice but I've been in some mighty tight situations with my tractor and I've always gotten myself out by using my FEL bucket. When I worked commercially in Florida there were many times I started sliding sideways down a slope of loose sand and was able to get out with very slow moves and that bucket. I guess the winch might be handy in very specialized instances, especially if you worked in the woods alot with it getting logs.
    2001 Mahindra 4110, FEL w/5' & 6' QA buckets & forks for the 5', 6' Atlas boxblade, older 6' Howse rotary, Leinbach 7300 PHD w/9" & 12", KK subsoiler, KK middlebuster, Kubota BL60C 5' tiller, Maschio 6' finish mower, Ford 2 bottom plow, 2014 Load-Max 24' GN equipment trailer, Country Clipper Edge XLT 60" mower.
  8. #8
    Super Member crash325's Avatar
    Join Date
    Feb 2011
    Posts
    9,962
    Tucson AZ
    New Holland TC-45
    Boy that is going to save a lot of space in the tractor shed.
    Just hang it up at night.
    ::"I STARTED out with nothing....I still have most of it."
    New Holland TC45 1,300+ hours - FEL - back hoe - post hole digger - Hydraulic Gannon - cement mixer - pressure washer - 1975 Dodge 500 flat bed - 1974 chevy C65 6 yard dump truck.
    All home made by me. loading forks - 2 drags - roller - Sheep's Foot - Pusher (to unload flat bed truck.) - pickle fork digger - Log splitter -
  9. #9
    Join Date
    Feb 2007
    Posts
    6,972
    Willis, Texas
    Mahindra 6520 4WD
    Glad to hear it. The winch looks a lot closer than 10 inches.
    hugs, Brandi
  10. #10
    Join Date
    Feb 2007
    Posts
    6,972
    Willis, Texas
    Mahindra 6520 4WD
    Quote Originally Posted by skipmarcy View Post
    Skip,
    Glad to hear the battery reposition stopped the overheating problems.
    hugs, Brandi
Similar Threads
  1. Snowblower Front end mount used on hardpack driveway
    By NHTC40D in forum Attachments
    Last Post: 05-19-2011, 08:16 PM
  2. How are front snowblowers mounted and powered?
    By Ken P in forum Attachments
    Last Post: 10-30-2010, 01:08 AM
  3. B2910/B7800 Front Mounted Snowblower
    By MIKEKUBOTA in forum Kubota Owning/Operating
    Last Post: 01-02-2009, 03:41 PM
  4. Diagram of front mounted blower?
    By pekabu in forum New Holland Owning/Operating
    Last Post: 08-22-2005, 08:59 PM
  5. front mounted blade link
    By KiotiJohn in forum Attachments
    Last Post: 12-17-2004, 01:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
