Results 1 to 4 of 4
09-06-2011, 11:15 AM #1New Member
- Join Date
- Sep 2011
- Posts
- 2
- Tractor
- mahindra 6000 2 wd
6000 2 wd pto shift lever problem
I just had a new pto shaft put in the 6000 and worked fine till yesterday. When I engaged it there was no grinding or anything but the shift just sorta went limp.....like it's not connected to anything inside. Is this accessible from the top under the seat? roll pin possibly holding the shift to the collar? I ordered a manual but it won't be here till Friday or so. Any help welcome> Thanks.
09-06-2011, 04:58 PM #2Veteran Member
- Join Date
- Jul 2003
- Posts
- 1,635
- Location
- Northern VA, USA
- Tractor
- Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
Re: 6000 2 wd pto shift lever problem
This is a dumb question, but did you check the PTO linkage from the lever back to where it goes into the left side of the differential?? BobG in Va
09-06-2011, 11:27 PM #3Veteran Member
- Join Date
- Sep 2005
- Posts
- 1,569
- Location
- Batavia, NY
- Tractor
- Mahindra -------------
Galen LaWall
185 Pearl Street
Batavia, New York 14020
585.343.0770
09-09-2011, 09:33 AM #4New Member
- Join Date
- Sep 2011
- Posts
- 2
- Tractor
I'll post this for anyone having the same problem. The lever goes into the left side of the tractor through a plate held by 3 bolts. Remove the step for better access, take the bolts out and work the pto lever assembly out the side. There is a shift lever on the end of the pto shaft that fits into a slip collar that rides on the pto shaft. On mine the little pin (kinda like a roll pin) had sheared and thus the shaft was just turning in the shift shaft lever. From what I have read and heard this is a pretty common problem with mahindras. I had to take a magnet to find the shift lever that had fallen. Anyway, not a bad fix. The little roll type pin costs about $2. I hope this helps someone else with similar problem.
Similar Threads
White Field Boss 37 PTO problem.
By klem531 in forum IsekiReplies: 12Last Post: 05-15-2012, 10:43 PM -
Ford 800 hard steering to left
By george46 in forum Parts/RepairsReplies: 16Last Post: 08-15-2011, 01:17 PM -
Help! b3030 PTO shift lever issue
By flowerfarmer in forum Kubota Owning/OperatingReplies: 8Last Post: 02-28-2011, 09:09 AM -
1864 PTO problem
By glenj44 in forum Cub Cadet L&GReplies: 1Last Post: 09-26-2010, 04:57 PM -
PTO shaft fun facts...
By Rara Avis in forum SafetyReplies: 2Last Post: 04-08-2008, 10:13 PM
