Results 1 to 4 of 4
  1. #1
    Silver Member nelsond7004's Avatar
    Join Date
    May 2011
    Posts
    112
    Coeburn, VA
    2009 Mahindra 2816 Gear
    Default 2816 - Front Differential - Gear oil or hydraulic fluid?
    Hi All,
    What are you thoughts on using gear oil over hydraulic fluid for the front differential? I have read several threads about Mahindra's owners manuals having conflicting information regarding hydraulic fluid or gear oil for the front differential. I have a 2816 gear and I am nearing my 200 service hour. When I performed my 50 hour service, I replaced the front differential fluid with McCormick HTX hydraulic fluid.
    Here lately I have been hearing and reading that gear oil might be a better option especially if you subject a tractor to a lot of loader work. I have been calling multiple Mahindra dealers in the area and 2 out of 4 recommend gear oil.
    I contacted Mahindra USA and they tell me they recommend trans-hydraulic fluid and go on to say that gear oil won't hurt either. I really want a piece of mind knowing that my front differential is getting lubricated properly.
  2. #2
    Approved Advertiser
    Join Date
    Nov 2002
    Posts
    370
    Bethany, CT
    Mahindra's
    Default Re: 2816 - Front Differential - Gear oil or hydraulic fluid?
    They come with trans/hyd fluid from the factory, thats what we put in when servicing them and have yet had a front diff failure.
  3. #3
    Elite Member
    Join Date
    Sep 2002
    Posts
    4,291
    Red Bluff, CA
    Changes often!
    Quote Originally Posted by nelsond7004 View Post
    Hi All,
    Mitsubishi, and therefore Mahindra, recommend hy-trans. But years ago they recommended gear oil. I'd say either works, but we always use hy-trans and that is the preferred fluid.
    Dave
    Dave's Tractor, Inc.
    Red Bluff, California
  4. #4
    Join Date
    May 2011
    Posts
    112
    Coeburn, VA
    Thanks for the replies. I will stick with the hy-trans. Most dealers that I have spoken to lately say that other big tractor names are using hydraulic fluid as well for the front differential.
Similar Threads
  1. Oil & Fuel 80w90 gear oil in Mahindra 5500 4wd
    By voltar0675 in forum Mahindra Owning/Operating
    Last Post: 10-07-2011, 08:08 PM
  2. gear oil vs hydro fluid (front axle)
    By wannabeRetired in forum New Holland Owning/Operating
    Last Post: 06-02-2011, 12:33 PM
  3. 80/90 gear oil or walmart tdh hydraulic fluid?
    By old roady in forum Oil, Fuel & Lubricants
    Last Post: 10-05-2010, 10:13 PM
  4. Hey Rox, what can you tell me about olive oil?
    By N80 in forum Rural Living
    Last Post: 09-03-2008, 05:10 AM
  5. 4WD final drive, gear oil instead of "hydraulic" fluid?
    By montejw in forum Oil, Fuel & Lubricants
    Last Post: 01-03-2007, 07:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
