Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    May 2011
    Posts
    8
    Mahindra 3505 di
    Default engine removal on 3510 Di mahindra
    Needs some help I have not been able to fine nothing on my 3510 Di it threww a rod in side of block tried to find a used block no luck. I was told could be welded . I need some info on pulling engine I was reading they said the tractor will have to be pulled in half in too. I tried to find a manual no dealers in small town if anyone have a diagram or any experiment on this please give me a email I need to
    pull the engine to see what all damage was done. please
    if anyone have any info get back to me please I don't want to scrap tractor out for parts.
  2. #2
    Join Date
    Sep 2005
    Posts
    1,569
    Batavia, NY
    Mahindra -------------
    Default Re: engine removal on 3510 Di mahindra
    Quote Originally Posted by Donhicks1 View Post
    Do you have a Mahindra 3510 or a Mahindra 350DI?
    Galen LaWall
    185 Pearl Street
    Batavia, New York 14020
    585.343.0770
  3. #3
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    5,686
    Northern California-Tehama Co.
    2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
    You need to split the tractor at the clutch bell housing/engine interface to remove that engine. Not hard to do if you have the time and the right equipment (floor jacks, jack stands, an engine floor crane).
    I don't have any info on your 3510 (my Mahindra is a 5525). However, you can get a good idea of what's involved in this video in which a Farmall Cub is deconstructed (my Cub is a 1951 model). The last 2 minutes shows the engine being pulled (i.e. the tractor has been split - finally).
    How to Take Apart A 1950 Farmall Cub Tractor - YouTube
    I like to handle engines with a bridge-type gantry crane (mine is a $500 from Harbor Freight--1 ton capacity). Here's it in use when I disassembled by 1951 Minneapolis Moline BF tractor for a complete restoration.
    engine removal on 3510 Di mahindra-dscf0068-small-.jpgengine removal on 3510 Di mahindra-dscf0035-small-.jpgengine removal on 3510 Di mahindra-dscf0047-small-.jpg
    Good luck.
  4. #4
    New Member
    Join Date
    May 2011
    Posts
    8
    Mahindra 3505 di
    Default
    Its a 3510 di 3 cyl engine
  5. #5
    Join Date
    Apr 2005
    Posts
    702
    Erin, Tenn.
    2001 Mahindra 4110
    If your tractor is the TYM built 3510, it is built just like my 4110 except for the engine size and I would assume is assembled just like mine. I have had mine split several times over the years and yes, you would have to split it in order to get the engine seperated for the repairs you say you need. The job isn't that bad if you have decent mechanical skills. I recently had to put a pressure plate in mine and split it with a floor jack and couple of jack stands on a piece of plywood on gravel, by myself in one day. Of course seperating the engine from the front half of the tractor will involve more time & work but I'm just giving you an idea of how a split isn't quite a terrible job that some might think. If you don't have the mechanical skills though, you could easily get hurt and/or cause more damage to your tractor. Good luck with whatever you end up doing with it.
    2001 Mahindra 4110, FEL w/5' & 6' QA buckets & forks for the 5', 6' Atlas boxblade, older 6' Howse rotary, Leinbach 7300 PHD w/9" & 12", MF 2/3 bottom plow, 20"x6' bog disc, KK subsoiler, KK middlebuster, Kubota BL60C 5' tiller, Maschio 6' finish mower.
  6. #6
    New Member
    Join Date
    May 2011
    Posts
    8
    Mahindra 3505 di
    Default
    Thanks for the info I am mechanical minded just trying to get as much info as I can before I start o will do the job myself u guys have bin a great help if anymore info before I state I really appreciate it
  7. #7
    Join Date
    Sep 2005
    Posts
    1,569
    Batavia, NY
    I've been a Mahindra dealer for 10 years and have never heard of a 3510 DI. The 3510 doesn't use a direct injection engine. If I new what you have, I could email you some parts breakdown pictures that might help you.
    Galen LaWall
    185 Pearl Street
    585.343.0770
  8. #8
    New Member
    Join Date
    May 2011
    Posts
    8
    Mahindra 3505 di
    Thanks my mystake it is a 3505 Di if you have anything on it I will appreciate it picture diagrams sorry for the mistake
Similar Threads
  1. LS vs. Mahindra
    By timebak in forum LS Tractors
    Last Post: 03-02-2011, 02:30 AM
  2. Help...Mahindra 3510 won't start
    By largeal in forum Mahindra Owning/Operating
    Last Post: 06-17-2007, 11:59 AM
  3. Comparison Mahindra 3510 versus Kioti DK35
    By frank29 in forum Buying/Pricing/Comparisons
    Last Post: 02-24-2006, 09:12 PM
  4. Smoke or condensation?
    By michaelTS354 in forum Chinese Tractors
    Last Post: 01-16-2006, 03:56 PM
  5. Engine Oil
    By RoyD in forum Ag Tractors & Machinery
    Last Post: 03-13-2001, 08:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
